Wireless Backup Camera Kit with 7” DVR Quad Split Monitor, 1080P FHD Rear Side View Camera, IP69 Waterproof + Parking Lines Reversing Cameras for Truck/Semi-Trailer/Box Truck/RV-B4C
Price: $629.95 - $409.99
(as of Aug 01, 2024 03:15:13 UTC – Details)
B4CB4C
With the help of the B4C system, you can get a good view and feel safer changing lanes. In busy traffic, you can see the cars behind you and your blind spots to maneuver or change lanes in traffic.
B3C B3C B4CX B3C
B3CB3C
Full HD graphics helps you view the surroundings in real time.
Monitor adopts Capacitive Button, different from traditional one, it can react more sensitively, Anti-static, better waterproof, besides it looks more pretty. High quality color and clarity make your driving and reversing safer.
B3CB3C
B4C B3C B3C 1 Product List 2 Dimensions 3 Easy installation
ZEROXCLUB Wireless Backup Camera Kit: Trusted by Millions of Customers!
7‘’ Capacitive Button Monitor
1920×1080
9‘’ Press Button Monitor
1920×1080
10‘’ Press Button Monitor
1920×1080
Spilt Screen & Multiple Views
Support single view, dual view and quad view.
IP69k Waterproof
Anti-fog and waterproof, suitable for Changeable weather.
IP69k Waterproof
IP69k Waterproof
Parking Guide Lines
Help you predict parking distance and reversing safely.
Parking Guide Lines
Parking Guide Lines
Compatible Vehicles
RV/Camper/Truck/Trailer/5th Wheel Trailer/Bus/Van/Motorhome/Farm Mach···
Compatible Vehicles
Compatible Vehicles
Truck/Trailer/Bus/Van/Farm Mach/RV/Firetrucks···
【FHD1080P Monitor with Capacitive touch-enabled buttons】FHD 1080 resolution gives you a unique visual exerience. The capacitive buttons don’t need press. Only put finger on the button in the sensing area, can be recognized by the machine. It gives you a sleek interface that cleans up easily.
【Upgrade Digital Wireless Signal】 Adopt HDCVI 4th Generation Digital Signal, 100ft anti-interference no delay, applicable for vehicles within 65 feet vehicle(12-24V), give you a stable and clear monitor of road condition, be your reliable assistant. The cameras are not battery camera and need wires to get power and work.
【Wireless Side View Camera & Recording】The Side View Camera can monitor the blind spot on the passengers side. It can help you have zero blind spots. Support Single View Dual View or Quad View(CH1/CH2/CH4), you can switch to the mode you need. Built-in 32G SD card, can record thing on driving.
【Night Vision & IP69 Waterproof】 Infrared Light and CCD Sensor accurately to capture crisp images from even in the dim condition. Closed with a Metal Gel, still work for you even at Rain /Snow/Fog, provide you all day intimate monitoring.
【Easy Installation & Wide Application】Wire camera to running light / tail lights/reverse lights to observe, Cigarette Lighter/ACC/Fuse/Radio can power monitor, Just connect power source and install antenna, you can start to use. Accommodate a large variety of vehicle as RV/Camper/Truck/5th Wheel Trailer/Bus/Van/Pickup.
Please note that the system transmits the camera image to the monitor via a wireless 2.4GHz signal. There is no cable between the camera and the monitor, but the camera and the monitor need power cord to get power and work, which saves yourself the trouble of charging and provide convenient and safe monitoring for your travels.
