Wireless Backup Camera for Truck Car : 7-Inch Touch Key Monitor Plug and Play No Delay No Dropped Frames Clear Brightness Rear View Camera 2 Channel Reverse Camera DIY Parking Lines AMTIFO A19
Price: $99.98
(as of Sep 16, 2024 08:00:17 UTC – Details)
Escort your driving and provide a better driving experience for you. backup camerabackup camera
The new Latest upgrade backup camera has super stable signal, so it can park safely and easily. And with the upgraded split screen, Backup camera makes you no longer feel anxious about the ambiguity of the previous system, bringing you unprecedented driving experience.
backup camera wirelessbackup camera wireless
backup camera  rv backup camera wireless  truck backup camera truck backup camera
1 Super Clear Night Vision
2 High Resistance
3 Simple and Quick Install
4 Dual-channel Wireless
What exactly comes in the package, specifically Does the Monitor come with a Suction attachment?
Yes ,It’s included suction cup mount.
Package include 1*Wireless Monitor, 1*Digital Wireless backup camera, 2*power cords, 2*Brackets for Monitor, 1*Cigarette lighter adapter, Antennas, Screws, 1*Instructions.
Can anyone install this system?
Plug and Play. Installation within 5 minutes. You only need to connect the camera and the monitor, and plug it to cigarette lighter , it will works
I don’t know how to install camera and how long is this camera guaranteed?
AMTIFO manuals and videos provide detailed usage and installation details, , if you have any more questions , please contact AMTIFO directly. This backup cam is backed by full 3-YEAR WAR-RANTY and 100% Satis-faction Gua-rantee.
Whether the system can be used in harsh environment, we live in a place below zero.
This A19 system can work in a long-term low-temperature environment. The system has been tested in multiple high-temperature and low-temperature environments and is made of stable chips.
Will the signal be lost during driving ?
The signal is stable when the system is in use. Before shipment, each system has been tested for extended distance to ensure the stable use of customers after receiving the goods.
rv backup camerarv backup camera A19 is Widely Used
Suitable for most of your models, whether you are installed in your car, SUV, truck, camper, trailer or ship, it can perfectly provide you with real-time vision.
Easy Installation – Wireless backup camera set for truck upgrade to wireless transmission,is easy to install within 20-30 minutes. No wired connection is required between the camera and the monitor. You just need to connect the monitor to the lighter charger, connect the rear view camera to running light or reversing light and you are good to go.
Super Stable Signal – High speed without interference, make it more convenient and safe to drive. Wireless back up camera systems for car is over 600ft in open area ,and under 33ft on vehicle with continuous use, no-interruption signal.
Parking Safely & Effortlessly – With wireless rear view camera for car, you will be able to easily park your car even in the tiniest parking spots.Without risking damaging it and ruining your day or night!
DIY Parking Grid lines – Wireless reverse camera for truck can adjust the parking line’s width, moving them Left/Right/Up/Down to make them portray real conditions, or you can also turn the parking guide lines off you prefer.
Upgraded Split Screen – Upgraded bluetooth backup camera wireless 7 inch monitor with two wireless video Inputs.You can add the wireless license plate camera for pickup truck as a hitch rear view camera or use it as a front camera.Or you can add the rv camera on a RV, Trailer, Camper, or Van etc.
HD 1080P Image and Super Night Vision– Equipped with great sensor, wireless truck rear view backup camera kit provides vivid picture , which restores what you see behind your car directly. Also back up camera upgraded no lights provide color picture at night.
Durable Camera Intelligent System – The wireless truck rear view camera with Super night vision, and wide viewing angles of 150°. Camera for car support on/off guide lines ,adjustable mirrored/normal view, flip images horizontal flip/vertical flip.
