Wireless Backup Camera for Furrion RV: 7-Inch Recording Plug-Play Easy Setup Truck Trailer Back Rear View Camera Touch Button Monitor Split Screen 4 Channels AMTIFO A7
Price: $174.98 - $135.98
(as of Sep 21, 2024 06:30:19 UTC – Details)
11
Welcome to AMTIFO Store
AMTIFO providing higher quality BACKUP CAMERAS. We know you will be pleased with our product.
AMTIFO brandAMTIFO brand
AMTIFO was created to eliminate blind spots, make driving safer and easier for everyone.
We focus on providing higher quality BACKUP CAMERAS. Designed a variety of cameras, you can choose 4.3-inch, 5-inch, 7-inch and 10-inch systems according to your needs, wireless or wired, and even add more cameras to the system, multi-directional escort.We’re sure you’ll get the satisfied system for your family and help to ensure years of safty.
AMTIFO Backup Camera
11
Customers Reviews
amtifo backup camera serviceamtifo backup camera service
amtifo backup cameraamtifo backup camera
backup camerabackup camera
reserving camerareserving camera
【Plug and Play】The rv backup camera kit is compatible with RV pre-wired for Furrion,installation was super easy with the provided Furrion mounting bracket adapter plate and pigtail wire,replaces expensive Furrion system.The wireless backup camera package included an array of accessories and extras, greatly simplifying the installation process.It was basically plug and play.
【Stable wireless signal】This backup camera is wireless and uses a 2.4-GHz communication system to give you a reliable digital connection. With the use of advanced IPS technology, deletes delays and improves response time.The rv backup camera with monitor upgraded dual antenna and unique digital stable signal. Its latest wireless technology ensures a fast and reliable signal without worrying about lag or disruptions.The signal can reach 825ft in open area and working on vehicle range under 320ft.
【Monitor with 4 Channels】The rv backup camera wireless system is capable of handling up to four cameras simultaneously, giving you a very comprehensive view of almost any blind spot on any RV. You can add license plate camera or same which comes with the rv camera system to for example install it on your truck /car or in front of your trailer (thong/tail) for easy connection or even inside your trailer to make sure your horses or your belongings are ok.
【Video Recording Function】To top it off rv wireless backup camera has a SD card video recording option that acts the same as a dash cam for what is happening around the RV or other things.Just in case you have to prove that someone rammed into the RV. Backup camera wireless built in record function and loop recording, continuous record when memory card is full and auto erase old files.
【Sturdy and Durable】AMTIFO back up camera for truck rv system featuring a resilient all-metal construction and ip69 waterproof rating, unlike some other cheap plastics, it is more heat resistant and less likely to bend or break.Even if it is exposed extreme weather, it will continue to send images to the driver.Also back up camera’s power IC on the motherboard has been upgraded from 35V to 60V, so you don’t worry about it stopping working like others.
[1080 RESOLUTION AND CLEAR NIGHT VISION] The rv rear view camera is equipped with the most unique CMOS image sensor and 1080P color chip to reproduce the truest colors, providing a seamless view of what’s going on behind campers and trucks, and the wide-angle view is perfect for seeing our tow vehicle and two lanes of traffic. On top of that,the rv reverse camera get up to 20 feet of reliable infrared night vision, live streaming while underway, and smart infrared cut filters.
【Other More Features】Combines trailer backup camera with a large 7-inch display so you can being able to see what is behind you when driving and to assist with backing up. The rv backup camera wireless with capacitive touch key sensor more durable and smoothly as well as extend the service life. In menu, You can switch the front view and rear view, and turn on or off the guide lines, which is very convenient. The picture is clear with adjustments for brightness, contrast, color etc.
【Quality Guarantee & Customer Service】AMTIFO rv rear camera came with a test cord kit. you were able to verify that it worked perfectly out of the box before you climbed up to mount the camera on the trailer. and include YouTube videos to help you along with the install and set up of the screens. Also we provide 30-day money-back guarantee and 2-year warranty. Free tech support and replacement service; We know you will be pleased with this camera.
【Security & Safety】You can also wire the camera to serve as a rv security system to help you stay safe when parked.T he guide lines so helpful and the most important ,adjustable up and down! Makes backing into your driveway and RV sites much easier, and nice to see what’s coming up behind you while driving down the road. It has completely changed someone who loves camping experience on the road.
