Wireless Backup Camera, 7 Inch Monitor Rear View Camera System for RV, Trailers, Trucks, 5th Wheels, Support 2 Cameras, IP69 Waterproof 18 LED IR Night Vision 152° View Camera, DIY Guide Lines
Price: $139.98
(as of Aug 07, 2024 23:00:26 UTC – Details)
wireless backup camerawireless backup camera
Two Installation Methods for Monitor
1) Sucked on the windshield with the suction cup mount
2) Mount on the dashboard with the bracket
Easy to Install
Power the monitor: Plug to the cigarette lighter receptacle.Power the camera:
1) Connect to the tail light for monitoring.
2) Connect to backup light for reversing only.
Wide View Angle
1) 152° backup camera captures a perfect wide angle and makes your reversing easier.
2) Designed for RV and travel trailer, high quality, more durable.
Image Flip Function
The default mode is mirror image for rear view. With image flip function you can switch to facing view(front view), or images upside down(vertical flip).
Colorful and Cristal Image
Digital wireless camera with HD 1080P monitor displays a colorful image during the daytime and super vision at night.
Waterproof IR Camera
Even in inclement weather, the 18 LED camera can still work well.
268
268
268
219
4.1 out of 5 stars
28
3.7 out of 5 stars
14
$299.99$299.99 $459.99$459.99 $139.98$139.98 $139.99$139.99 $159.99$159.99
Monitor Size
10 Inch 10 Inch 7 Inch 5 Inch 9 Inch 9 Inch
Spilt Screen
Full / Dual / Quad Full / Dual / Quad Full / Dual Full / Dual Full / Dual / Quad Full / Dual / Quad
Record Function
Parking Guide lines
ON/OFF ON/OFF ON/OFF ON/OFF ON/OFF ON/OFF
Number of Cameras
3 4 1 2 4 2
Maximum Number of Supported Cameras
4 4 2 2 4 4
Compatible Vehicles
RV/Truck/Trailer/Semi-Trailer/Camper/Pickup/5th Wheel Trailer/Motorhome/Bus/Van RV/Truck/Trailer/Semi-Trailer/Camper/Pickup/5th Wheel Trailer/Motorhome/Bus/Van RV/Truck/Trailer/Semi-Trailer/Camper/Pickup/5th Wheel Trailer/Motorhome/Bus/Van RV/Truck/Trailer/Semi-Trailer/Camper/Pickup/5th Wheel Trailer/Motorhome/Bus/Van RV/Truck/Trailer/Semi-Trailer/Camper/Pickup/5th Wheel Trailer/Motorhome/Bus/Van RV/Truck/Trailer/Semi-Trailer/Camper/Pickup/5th Wheel Trailer/Motorhome/Bus/Van
🚚🚚 Stable HD 1080P Image – The 7 inch TFT-LCD monitor with 2.4G wireless digital transmission, presents high-definition images for reversing or monitoring. What’s more, it could delivers a stable image without any interference from other wireless signals. Monitor size: 7.48(W)*4.92(H) inch. Camera size: 3.15(W)*1.77(H) inch
🚚🚚 Waterproof Rearview Camera – With IP68K waterproof standard, 152° wide view angle, the high-resolution sensor & 6 glass lens ensures high-definition and smooth image quality! The highest and lowest temperature resistance is -4°F~176°F. Suitable voltage range is 12V-24V
🚚🚚 Wireless System & Easy Installation – The backup camera system with digital wireless transmission makes the installation much easier. Just connenct the camera and monitor separately to power supply: (1) Power the monitor by the included cigarette lighter or Fuse box, ACC, Ignition switch. (2) Connect the camera to continuous power source like Tail light/Running light/license plate light for monitoring, or connect to backup light for reversing only
🚚🚚 Long signal transmission distance – The max wireless working range is over 300ft in open area ,and 50ft on vehicle for reversing or 36ft on vehicle for continuously use, which is long enough for most vehicles, like Cars, Trucks, Pickups, Camper, SUVs, Trailers, and Minivans. Besides, the suction cup mount allows you to install the monitor on either windshield or dashboard, without drilling holes into your dash.
🚚🚚 IR Night Vision & Split Screen – The lumen rating is 0.01 at low light night, giving you an extraordinary visual experience with colorful images. You can still watch 60 feet vision even in a dark environment. This system supports 2 cameras, press “C” button to switch for Cam1/Cam2 or both cameras. (Please kindly note that the second wireless camera need to purchase separately)
