Price: $299.99 - $269.99
(as of Aug 07, 2024 11:30:20 UTC – Details)
AHD backup camera system for truck RV bus trailer.
The 10-inch HD display with 4 AHD 1080P reverse rear view & side view cameras is more suitable as a back up camera system for Trucks RVs Trailers Fifth Wheels and other large vehicles.
Note: We focus on backup camera systems for large vehicles such as Trucks, RVs, Buses, Vans, Tankers etc.; Due to the large size of the 10-inch touch monitor and wired camera as well as the extension cables, it may not be suitable for Cars, Minivan, SUV, Off-Road Vehicle etc., so in order to avoid wasting your time, please confirm the use of the car model in advance.
AHD 1080P
Durable&Waterproof Backup Camera
Recording and Playback
High Quality Image
Normal&Mirror Image
Supprt split screen
Guide lines ON/OFF
What’s in the Box?
Monitor*1 10.1inch IPS Panel Backup Camera *1 AHD1080P Side View Camera*2 AHD1080P Front View Camera*1 AHD1080P 49 ft Cable*1 49 ft Cable*1 23 ft Cable*3 23 ft Cable*3 Memory card*1 64GB Cigarette lighter*1 Car Charge Adapter
【1080P backup camera system】Make the installation of backup camera for truk/RV more diverse! All 4 Backup Cameras have night vision. At the same time, all of them use AHD high-definition technology to achieve 1080P high-definition picture quality. Once you get it, you will find that it is not a product of an era at all with other CVBS cameras.
【Back up Camera with Recording Function】 RV Backup camera system has recording function. it can also be connected to 12V-36 V range power source.In addition, this product supports 4 cameras for video recording at the same time, which allows you to record every pleasant trip you have made.
【Now, into the big screen world】 That’s the change that 10.1 inch big screen Back monitors bring to us! Because the display area is much larger than other 5-inch and 7-inch monitors, even if you adjust the screen to a 4-segment display, you can see it clearly and work more efficiently.
【Images Mirror Switch】 You can turn on the front or mirror display of each camera individually from the menu list. 【Guide Line ON/OFF/DIY】 You can set the guide line to always display, display after triggering, or turn off as needed.
【Easy for Installation】You only need to insert the cigarette lighter adapt into the cigarette lighter socket to supply power to the system and avoid the traditional complex power supply. You only need one cable to connect the monitor and camera, and then you can complete the installation after wiring.
【2-year manufacturer’s warranty】We provide 2-year manufacturer’s warranty.
