Wired Backup Camera System, 10.2″ 1080P Quad Split Monitor with DVR, IP69K Waterproof Rear View Car Reversing Camera x 4 with Parking Lines, Suit for Truck, RV, Camper, Pickup, Trailer, Bus
Price: $199.99
(as of Sep 05, 2024 01:30:18 UTC – Details)
Fursom 1080P 10.2” DVR WIRED BACKUP CAMERA – Your Reliable Backer for Safe Driving and Reversing
Parking Line Assistance
With this wired backup camera kit, it will show the parking image or parking assist lines when you reverse your vehicle.
170° Wide Angle
Fursom backup camera with the wide lens can provide a 170° wide vision providing more details on road. Making your driving and parking safer and easier.
Image Flip
Support normal and mirror image or rotate image to avoid any blind spots.
Split Screen Monitor
You can choose to view 4 cameras images at the same time or just view one of the cameras in full screen. Easily change the display settings by press “CH-” button.
Super Night Vision
A light sensor at the front of the camera automatically turns on 18 infrared LED lights in low light conditions to provide clear night vision imagery whenever it is required
Loop Recording Function
Supports Max.128GB SD Card (Package comes with a 32G SD Card)
Loop recording DVR function allows you keep video in SD card, you can playback the videos on the monitoror computer. It will automatically overwrite the earliest video when the memory is full.
Package Content
Rear View Camerax 2
Side View Camerax 2
10” Monitor x1
33ft Video Cable x2
66ft Video Cable x2
32G SD Card x1
Power Cord x1
Sun Visor x1
Remote x1
Fan-shaped Bracket & Sticker x1
U-shaped Bracket & Sticker x1
Upgraded Stand x 2
Installation Accessories x 1
10.2” Quad Split Display & Loop Record – The super large 10.2 inch monitor with 1920×1080 pixels has multiple displaying modes: Full Screen/ Dual Split/ Tri Split/ Quad Split. You can see four images at the same time or just monitor some of them. Loop recording DVR feature allows you keep video proof whenever it’s needed (including a 64G SD card).
Stable Signal & Weatherproof Camera -The wired camera system are more stable than wireless version, no image lag and signal interference issues. IP69K rated and stainless-steel housing, working temperature ranges from -4°F – 176°F. This font side and rear view camera kit is completely waterproof and withstand all severe weathers.
Parking Grid Lines & 170° Wide View – The vehicle backup camera system can automatically measure the rear distance and trigger the parking grid lines on the monitor when you’re reversing, which helps you parking quickly and safely without someone else’s guidance. The 170° super wide viewing angle captures more details to avoid blind spots.
Versatile Vehicle Compatibility – Support voltage from 9-36V DC power to work with a wide range of oversize vehicles such as Trucks, Bus, Box Truck, Semi-Trailers, Tractor, Van, RVS, Motor home, etc.
Easy Installation & Service – Hard wiring system can be easy to install by follow our detailed instructions. If you need any assistance or extra cable, please ask us for help. We’re online 24/7, offering 2 years warranty and lifetime technical support for our products.
