Price: $189.99
(as of Aug 21, 2024 21:00:22 UTC – Details)
ATPTK, THE EXPERT OF VEHCLE CAMERAS.
We are professional, in the field of vehicle camera for more than 14 years.
This is a single camera kit. It can be used for any kinds of large vehicles, such as buses, box trucks, pickup trucks, garbage trucks, flatbed trucks, dump trucks, street sweeper trucks, refrigerator trucks, motor homes, vans, skid steers, farm tractors, combines, cotton pickers, crop sprayers, bulldozers, snow plows, forklifts, excavators, heavy equipments,etc.Camera can be mounted at the back/front/side of your vehicle.Monitor also can be mounted on the roof of the cab.Powered by vehicle power DC12-32V. Red wire to ACC 12-32V negative, and the black wire to positive (GND).Trigger wires are for turning signal power to make the monitor display when turing or reversing, or kept blank to display all the time.
On-screen Image Rotation(mirror/non-mirror)
If camera has to be mounted up-side-down or in front. No worry, just roate the image on the screen by menu to get a right visionIf monitor has to be mounted on the roof. No worry, just rotate the image on the screen by menu to make it be displayed vertically.
You can mount your camera and monitor in any direction.
High Resolution Monitor
The monitor has a high resolution of 720P.
When parking, with the guide line or rear distance scale on screen, there is no more guess for you if the bumper gets closer to the object behind.With the guide line, it helps you parking faster and safer.
What you shoud do at the frist time is to turn the guide line ON via menu, then connect the trigger wire to the power of reversing gear. As long as you put your vehicle into reverse, the guide line will show up on the screen.
Max 3 Cameras
Monitor is able to take up to 3 cameras, and displays one by one automatically or manually.
In this kit, it only inlcudes one camera.
Waterproof Camera IP69K
The camera has the highest level of waterproof and dustproof rating IP69K. When raining, you also can drive safely.And it also has 10G vibration resistance rating.
It is not only suibale for trucks, bues, caravans, etc., it is also suitable for heavy equipments, farm tractors, skid steers, etc. in extreme condition.
Night Vision Camera
To keep your safe driving at night
Our camera has 18 IR lights. When reversing at night, with our camera you are able to see what is behind your vehicle.
TVS Built-in
The transient voltage often ocurs in the circuit of your vehicle when winding up/down the window, turning on/off the air-conditioner, etc. It may damage some device in your vehicle. No worry!Our monitor has been built-in with TVS to protect the system from being damaged by the transient voltage.
What is in the package
9″ LCD monitor X1Waterproof camera X1Monitor U-type bracket, sunvisor and screw X1Monitor power cable X149ft extension cable X1
【APPLICATIONS】This is an upgraded industrial grade wired one camera system. For its high vibration resisance ability of 10G and wide power input range DC12-36V, it is suitable for large vehicles, such as buses, box trucks, pickup trucks, garbage trucks, flatbed trucks, dump trucks, street sweeper trucks, refrigerator trucks, motor homes, vans, skid steers, farm tractors, combines, cotton pickers, crop sprayers, bulldozers, snow plows, forklifts, excavators, heavy equipments,etc.
【MONITOR】9”LCD AHD 720P color monitor with U-type metal bracket and with 1024RGB x600 HD resolution. It is not waterproof. It is compatible with most of the vehicles with a free power input range DC12-32V and supports with max 3 cameras. TVS device is built in to protect the monitor from being damaged by the transient high power of vehicles. And this monitor only supplies camera which is in use with DC12V, it saves energy. It is compatible with PAL/NTSC.
【HEAVY DUTY CAMERA】It is color AHD 720P, provides super clear and real color image, and no delay. The viewing angle is 120 degree. With waterproof rating IP69K(the highest level), with night vision. So it works perfectly in kinds of weathers. With Heavy duty, 10G vibration-proof rating, it works well with the vehicle which has intensive vibration in extreme conditions.
【Unique Selling Proposition】①.The buttons have automatic LED backlight, drivers can operate exactly at night. ②.Monitor has a built-in protector for protecting monitor from being damaged by power polarities reversed. ③With built-in innovative system previous option settings memory even after it’s turned off. ④.Camera’s image can be set as mirror, non-mirror or up-side-down by OSD menu. ⑤Turn the distance grid line on by menu, then connect trigger wire to power, it will show.
【Unique Selling Proposition】①Monitor has two trigger wires. Monitor will be triggered to be turned on automatically to display camera image when reversing. After reversing, the monitor will be back to the pervious mode. ②This system has two viewing options(view when reverse or remain on continuously). ③We uses waterproof Aviation 4-pin screw connectors, NO BNC/RCA. ④Easy to install. ⑤Two-year warranty and life-time tech support.⑥Contact us to tell us your needs, we can customize a kit for you.
