Winegard PL-8000 White Dish Playmaker HD Satellite Antenna Dual Receiver Capability, Optional RV Roof Mount
Price: $336.87
(as of Aug 10, 2024 22:45:13 UTC – Details)
The Winegard DISH Playmaker Dual portable satellite antenna is specially designed for watching DISH HD programming while in the RV, camping, hunting, or make your tailgate party the ultimate tailgater! This easy to use portable satellite system automatically finds satellite programming with no antenna pointing. Larger high-strength aluminum alloy reflector for improved signal strength and optional RV roof mount. Easy to use and lightweight RV portable satellite dish. Requires minimal space making it easy to take with you wherever you go. Perfect for the RV, camper, motorhome, cabin, hunting or become the ultimate tailgater with the DISH Playmaker. Built and tested to withstand the harsh conditions on an RV roof. Compatible with DISH Pay-As-You-Go, pay only for the months you need, or add to your home DISH satellite service.
Dish Playmaker Dual portable satellite antenna – featuring dual coax outputs, Watch different programming on two different TVs on the same satellite
Easy setup portable antenna – powered by single coax connection through dish receiver
Fully-automatic satellite dish – automatically finds dish HD satellite orbital locations making it easy to watch your favorite TV shows. Compatible Satellites- DISH: 61.5° (SD/HD) 110° (SD/HD) 119° (SD/HD) 129° (SD/HD)
Optional roof mount – Optional RK-4000 roof kit allows you to mount the dish Playmaker satellite antenna To your RV’s roof
Enjoy dish TV in HD – works exclusively with dish HD Solo satellite receiver technology and programming
