Westinghouse 194Wh 300 Peak Watt Portable Power Station & Solar Generator, Modified Sine Wave AC Outlet, Backup Lithium Battery for Camping, Home, Travel, Indoor/Outdoor Use (Solar Panel Not Included)
Price: $129.98
(as of Aug 10, 2024 10:30:20 UTC – Details)
The Westinghouse iGen200s Portable Power Station is a no-hassle solution for your power needs. Built with a lithium-ion battery for clean power, the iGen200s is maintenance-free and produces no noise and no fumes for safe use indoors or outdoors. This power station is solar panel capable for environmentally friendly charging wherever you are. Providing 194 watt hours of power with 150 continuous watts and 300 peak watts, it’s designed to power all your necessary electronic devices during all your activities such as camping, tailgating, and festivals. The control panel features three USB ports, two household outlets, a 12V DC outlet, and an LED display. The LED display provides information on the wattage, charging status, and remaining battery life. The iGen200s is built with a lock feature to protect against accidental power drain. Sturdy and compact construction makes this power station easy to take wherever you go or easily store when not in use. Providing ease of use and a name you can trust, rely on the Westinghouse iGen200s for your portable power needs.
VERSATILE OUTLETS CHARGE UP TO 6 DEVICES AT THE SAME TIME: Pushing 150 Rated and 300 Peak Watts Through (2) 120V Household Outlets, (1) USB Port, (1) Quick Charge USB Port, (1) USB-C Port, (1) 6mm 9-12V DC Outlet, (1) 12V Cigerette Lighter Outlet – Strong Enough To Easily Power 50″ LED TV, Humidifer, or Refrigerator
HOURS and HOURS OF POWER ON A SINGLE CHARGE: 194 Watt-Hours of Li-Ion Battery Capacity – Provides Long-Lasting Power That Charges Smartphones Up to 21 Times, DSLR Cameras Up to 20 Times, Bluetooth Speakers Up to 13 Times – Delivers Hours of Power to a Nintendo Switch, Drones, and Food Warmers/Heated Lunchboxes
LIGHTER THAN BLUETOOTH SPEAKER: At 4.03 lb Lighter than JBL Xtreme Wireless Speaker, Smaller Than a Lunchbox – Backpack Ready Mini Generator With a Convenient Carrying Handle and Built-in Tri-Mode Flashlight – Perfect Compact Charging Station for Camping and Other Outdoor Activities
CHARGES AT HOME, ON THE GO, OR IN THE FIELD: Charge to 80 percent in Less Than 4 Hours Using a Household Outlet or Less Than 5 Hours in the Car or With a Solar Panel (Panel Not Included)
ECO-FRIENDLY, POWER GENERATOR: Reduce Your Carbon Footprint for More Sustainable Lifestyle – No Obnoxious Fumes, No Messy Maintenance, No Noise Pollution – Whisper Quiet Indoor and Outdoor Generator
NO ACCIDENTAL POWER LOSS – POWERLOCK TECHNOLOGY: Unique Feature Locks Outlets and Flashlight From Power Drain – Safe for Sensitive Electronics – Short Circuit, Overload, and Temperature Protections for Worry-Free Use
WHAT’S INCLUDED: AC Adapter, DC Adapter, Cigerette Lighter Plug, Manual – Backed by 2-Year Coverage With Limited Service, Labor, and Parts Coverage With Nationwide Customer Service Network
