Weize 200W 12 Volt Solar Panel Starter Kit with 30A PWM Charge Controller, High Efficiency Monocrystalline PV Module for Home, Camping, Boat, Caravan, RV and Other Off Grid Applications
Price: $99.99 - $89.99
(as of Aug 30, 2024 03:15:15 UTC – Details)
solar panel 100W newsolar panel 100W new
solar panel 100W detail 1solar panel 100W detail 1
Maximum Power Output: 100W
Maximum Power Voltage (Vmp): 18.46V
Maximum Power Current (Imp): 5.41A
Maximum System Voltage: 1000V DC
Open-Circuit Voltage (Voc): 21.69V
Short-Circuit Current (Isc): 5.7A
Dimensions: 44.09 x 17.72 x 1.18 inch
Panel Weight: 12.65 lbs
solar panelsolar panel
What is Needed for a Solar System:
– Solar Panel(s), connecting more by series or parallel to get 12v, 24v or 200w 300w…etc;
– Charger Controller, voltage & current regulator keeping your battery from overcharging.
– Connecting Cables, put the solar panel, charger controller, battery together;
– Mounting Brackets, you may need them to install the panel in full sunshine place.
– Power Inverter (optional), convert the DC to AC power for AC devices.
11
11
solar panel detail 5solar panel detail 5
Perfect Design
MC4 cable, overall length 32.68 inch;
Pre-drille holes, easy for installation;
IP65 rated waterproof junction box.
Good Quality
Advanced material with multi-layered sheet;
Aluminum frame, anti corrosion;
Durable low-iron tempered glass;
High Efficiency
High module conversion efficiency 21%
44.09 x 17.72 x 1.18 inch, with Max. 100W;
About produce 300-600Wh / Day.
Coming with Accessories as Below:
MC4 Extension CableMC4 Extension Cable
Solar panelSolar panel
MC4 ConnectorsMC4 Connectors
Mouting BracketsMouting Brackets
MC4 Cable
1 Pair of 20ft MC4 Cable
1 Pair of 8ft Tray Cable
Charger Controller
30A PWM Charger Controller(black or white)
MC4 Connector
1 Pair of MC4 Connectors
Mount Bracket
2 Set of Mounting Brackets
4.6 out of 5 stars
61
503
361
4.2 out of 5 stars
29
3.1 out of 5 stars
21
— $89.99$89.99
Maximum Power
100W 200W 100W 1200W 2000W
Cell Type
High-Efficiency Monocrystalline High-Efficiency Monocrystalline High-Efficiency Monocrystalline
Voltage
12 Volt 12 Volt 12 Volt 12 Volt 12 Volt
Dimensions
44.09″ x 17.72″ x 1.18″ 44.09″ x 17.72″ x 1.18″ 44.09″ x 17.72″ x 1.18″
High Efficiency: WEIZE solar panel is constructed with high-performance Monocrystalline solar cells that offer higher efficiency up to 21% than Polycrystalline in bright weather condition, it provides a long service life and is virtually maintenance free.
Durable: The anodized aluminum frames, tempered glass and sealed junction box make the solar panel corrosion-resistant and weatherproof for superior outdoor performance.
Versatile: The industrial-standard solar panel features 39.96″ x 20.27″ x 1.18″ size, 2.6ft cable with connectors, produces 300-600Wh a day, generates 5.3 amp power, charges 12 volt battery, ideal for RV’s, cabins, sheds, remote locations and other small power generation needs.
Installation Ready: Equipped with all necessary accessories that include: 1*30A PWM charger controller (intelligent protection against reverse polarity, overcharging, short-circuit, and reverse current.) , 1 pair 20ft extension cables, 1 pair of 8ft battery tray cable, 1 set mount brackets and screws (Battery and inverter are NOT included).
Warranty: WEIZE 200W solar panel starter kit aims for quality followed up with quality customer service directly provided by manufacturer. A satisfied solution will be given for ANY of your problems. Our support team is on standby for YOU.
