WEIZE 12 Volt Car Refrigerator, 16 Quart/15 L Portable Freezer Compressor Cooler, -4℉~68℉ Fast Cooling RV Fridge, 24V DC & 100/240V AC for Car, RV, Truck, Van, Boat, Camping, Travel (APP Control)
Price: $199.99
(as of Aug 07, 2024 08:15:10 UTC – Details)
11
11
Specification:
Capacity: 16 Quart(15L)
Weight: 8.6KG(18.96Lbs)
External Size: 598 x 320 x 260 mm(23 1/4″(L)x12.6″(W)x10.2″(H))
Home use: 100 V-240 V AC power
Car/Big truck use: 12/24 V DC power
Wattage: Max Mode 60W
Noise Level: ≤45 dB
Fridge/Freezer: -20~20℃ (-4~68℉)
Package: 1 * User manual 1 * portable freezer 1 * AC adapter 1 * DC power cord NOTE:Let it stand for 12 hours when you use it for the first time
c15 car fridge outdoor campingc15 car fridge outdoor camping
APP Control
The car fridge supports APP control and manual control. With the intelligent design, it’s more convenient for you to monitor the temperature of the car refrigerator at any time. And Its USB port allows you to conveniently charge your phone.
11
11
11
Anti Shake
At 30° of tilt, the fridge can operate safely. There is no need to worry about rugged roads.
Low Noise
With this 45 dB low noise car fridge, you will not interfere with sleep and driving, whether in the car or at home.
Supports Charging
You can use a charging cable to charge your phone.
11
11
11
Convenient and Reliable
16 Quart(15 Liter) capacity ,fits 20 cans of Cola.The thick material will make the refrigerator lock the temperature without leaking cool air. Keep the item fresh all the way on your trip.
Battery Protection
Your car battery is safe with the L/M/H level battery protection feature,You could change to ECO mode for energy-saving after the temperature has gotten to the pre-set, which allows you to camp and stay put for a more extended period.
Fast Cooling
the car refrigerator can cool to 32°F at most in 15 minutes;it takes about an hour to reach its lowest temperature of -4°F (-20°C).
11
4.2 out of 5 stars
40
34
4.5 out of 5 stars
26
3.9 out of 5 stars
37
Volume
22L 30L 35L 45L 55L
Temp Range
-4℉~68℉(-20℃~20℃) -4℉~68℉(-20℃~20℃) -4℉~68℉(-20℃~20℃) -4℉~68℉(-20℃~20℃) -4℉~68℉(-20℃~20℃)
AC&DC
Anti Shake
Low Noise
Battery Protection
Interior Light
APP Control Applicable
【Intelligent Car Refrigerator】: WEIZE car refrigerator is newly upgraded and can use Bluetooth connection. It allows you to adjust the temperature of the refrigerator with your phone anytime and anywhere while driving, without having to stop the car and run to the location of the refrigerator to adjust the temperature.
【Portable Large Capacity】: Exterior Size- 23 1/4″(L)x12.6″(W)x10.2″(H). 16 Quart(15 Liter) capacity ,fits 20 cans of Cola. It could be a fridge or freezer to keep food, drink or medicines at a right temperature, such as Beverages, Fruits, Ice Cream, Vegetables, Seafood, Meats, Skin Care, and breast milk, insulin. Best portable refrigerator for picnic, barbecue, camping, travel.
【Fast Cooling】: Reliable sealing property construction,thick and high Density Foam Insulation.the car refrigerator can cool to 32°F at most in 15 minutes;it takes about an hour to reach its lowest temperature of -4°F (-20°C).
【Power-saving Mode】: The camping fridge equipped has 3 different levels for battery protection: Low, Med and High to protect your vehicle battery without run down.maximizing car’s battery life.Its USB port allows you to conveniently charge your phone.
【AC/DC Adapters】: The WEIZE 15L fridge/freezer includes( 1 * User manual/ 1 * 12/24 Volt DC Power Cord/ 1 * 100~240 Volt AC Power Cord) which seamless use whether at home or in your car.
