Waveform QuadPro 4×4 MIMO Signal Boosting Panel Antenna Kit | External Antenna for 4G/5G Routers & Gateways | for T-Mobile Home Internet, Verizon, AT&T (Complete Kit w/ 20′ Cable & Window Entry)
Price: $449.99
(as of Sep 10, 2024 02:30:31 UTC – Details)
Waveform Brand StoryWaveform Brand Story
Become a Signal HeroBecome a Signal Hero
Devices with 4 Antenna Ports
Devices with 2 Antenna Ports
Standalone Antennas
About WaveformAbout Waveform
CUTTING-EDGE 4×4 MIMO PERFORMANCE – Want faster data rates, greater reliability, and lower latencies? Your 5G Internet is only as good as your 5G cell signal. Join tens of thousands AT&T, Verizon, and T-Mobile customers who have dramatically improved their Internet connectivity with a Waveform antenna. With full 4×4 MIMO support and up to 9.1 dBi gain from 600 to 6000 MHz, the Waveform QuadPro supports every 4G and 5G band from every carrier, including AT&T, Verizon, T-Mobile, and US Cellular.
ALL-IN-ONE KIT, NEW & IMPROVED: The best MIMO Panel antenna on the market just got even better. Comes packaged with our one-of-a-kind Window Entry Cable, FlexMount, Pole Mount, UltraFlex-Quad cable and weatherproofing boots, to make installation easier than ever and eliminates the need to drill holes in your home.
DIRECTIONAL, REQUIRES AIMING – Aim QuadPro at your nearest tower for blazing data speeds and unbeatable reliability, even at the edges of cellular coverage.
SIMPLE DIY INSTALL: Use the included FlexMount, Window Entry Cable, UltraFlex-Quad cable, SMA, and U.FL adapters, as well as our detailed install guide, to quickly and easily get your antenna online and connected to almost any 5G router, modem, or gateway.
T-MOBILE HOME INTERNET SUPPORT: Detailed guides for connecting to every TMHI gateway, including the G4AR/G4SE, Nokia 5G21, Arcadyan KVD21, Sercomm Fast 56WW Gateways. Also works with Verizon 5G Home Internet and AT&T Internet Air.
COMPATIBLE WITH VERIZON, CRADLEPOINT, PEPLINK, MOFI, NETGEAR, AND MORE: Our 4×4 antennas work with AT&T, Verizon, T-Mobile, 4G LTE or 5G, and almost any modem and router manufacturer. As long as there’s a way to connect external antenna ports, our MIMO antennas can help you get dramatically faster Internet connectivity.
UPGRADE TO BLAZING-FAST CELLULAR INTERNET – Data rates aren’t just about signal strength. QuadPro is optimized for the highest possible 5G performance with high MIMO isolation and +/- 45 degree polarization.
