Waveform 2×2 MIMO Panel Antenna | 4G and 5G Compatible Modem, Router, Gateway and Hotspot Antenna Kit | Compatible with AT&T, Verizon, and T-Mobile Home Internet | Antenna Only
Price: $99.99
(as of Sep 01, 2024 17:00:20 UTC – Details)
Say goodbye to laggy Zoom calls, Netflix buffering, and High Ping gaming! If you’re looking for faster data speeds with your LTE router, you’ve found the right product! The waveform MIMO Panel Antenna kit utilizes a panel antenna that houses two cross polarized antennas to maximize the reception of your LTE modem. Our kit gives you everything you need to attach these antennas to your LTE Modem with our 3 pack of adapters. Simply use the adapters to connect to your hotspot, connect the adapters to the coax cable and mount your antenna somewhere outside, ideally lower than the highest peak of the roof to enjoy some faster data rates!
SAY GOODBYE TO LOW QUALITY VIDEO CALLS – The MIMO Panel Antenna Kit by Waveform uses a Cross-Polarized Panel antenna, with up to 8dBi of gain over 600-2700MHz to give your LTE modem or hotspot the speed it deserves.
NO MORE BUFFERING STREAMS OR VIDEOS – Using multiple connections means you’ll get much more signal into each antenna compared to what the small internal antennas of your router can currently pull from a tower, maximizing the efficiency of your device.
TWO ANTENNA CONNECTIONS, TWICE AS MUCH SIGNAL – Using a MIMO enabled router and antennas gives you double the signal being sent and received into the device rather than a single channel of data.
BUY OUR KIT TO CONNECT TO EVERYTHING – Our three pack of adapters helps you connect to all major models of LTE routers, including the T-Mobile 5G gateway, without any additional purchases!
NOT JUST AN ANTENNA! – Purchasing this antenna gives you access to Waveform’s dedicated support team for the lifetime of the product. We’re available by text or phone call during regular business hours 7 days a week. Whether you’ve had this antenna installed for years or just purchased it, you’ll have a team of support specialists that you can rely on for assistance. We believe our products will work 100% of the time given the proper conditions, and are happy to do all we can to help!
ROUTERS SUPPORTED – Mofi 4500 | Netgear LB1120, 2120, MR1100, MR5100 | ATT IFWA40 / MF279 | Cradlepoint IBR900 | Verizon Mifi 8800L, 7730L, and many more!
