Price: $349.99 - $239.99
(as of Sep 10, 2024 14:00:28 UTC – Details)
Say goodbye to laggy Zoom calls, Netflix buffering, and High Ping gaming! If you’re looking for faster data speeds with your LTE router, you’ve found the right product! The waveform MIMO Log Periodic Antenna kit uses 2 cross polarized LPDA “yagi” antennas to maximize the reception of your LTE modem. Our Kit gives you everything you need to attach these antennas to your LTE Modem with our 3 pack of adapters. Simply use the adapters to connect to your hotspot, connect the adapters to the coax cable and mount your antenna somewhere outside, ideally lower than the highest peak of the roof to enjoy some faster data rates! Bands supported :AT&T: B2, B4, B5, B12, B17, B29, B30, B66 | Verizon: B2, B4, B5, B13, B66 | T-Mobile: B2, B4, B5, B12, B66, B71 | Sprint: B25 B26, B41| Band 2 (1900 MHz) | Band 4 (1700/2100 MHz) | Band 5 (850 MHz) | Band 12 (700 MHz) | Band 13 (700 MHz) | Band 14 (700 MHz) | Band 17 (700 MHz) | Band 25 (1900 MHz) | Band 26 (850 MHz) | Band 30 (2100 MHz) | Band 66 (2100 MHz) | Band 71 (600 MHz) | All supported 5G Bands: n1, n2, n3, n5, n7, n8, n12, n14, n18, n20, n25, n26, n28, n29, n30 n34, n38, n39, n40, n41, n65, n66, n70, n71, n80, n81, n82, n83, n84, n86, n89, n90, n95
SAY GOODBYE TO LOW QUALITY VIDEO CALLS – The MIMO Log Periodic Antenna Kit by Waveform uses Cross-Polarized Yagi antennas, each with up to 11 dBi of gain over 600-6000MHz to give your LTE modem or hotspot the speed it deserves.
NO MORE BUFFERING STREAMS OR VIDEOS – Using multiple connections means you’ll get much more signal into each antenna compared to what the small internal antennas of your router can currently pull from a tower, maximizing the efficiency of your device.
TWO ANTENNAS, TWICE AS MUCH SIGNAL – Using a MIMO enabled router and antennas gives you double the signal being sent and received into the device rather than a single channel of data.
BUY OUR KIT TO CONNECT TO EVERYTHING – Our three pack of adapters helps you connect to all major models of LTE routers, including the T-Mobile 5G gateway without any additional purchases!
NOT JUST AN ANTENNA! – Purchasing this antenna kit gives you access to Waveform’s dedicated support team for the lifetime of the product. We’re available by text or phone call during regular business hours 7 days a week. Whether you’ve had this antenna installed for years or just purchased it, you’ll have a team of support specialists that you can rely on for assistance.
ROUTERS SUPPORTED – Mofi 4500 | Netgear LB1120, 2120, MR1100, MR5100 | ATT IFWA40 / MF279 | Cradlepoint IBR900 | Verizon Mifi 8800L, 7730L, and many more!
