VTOMAN Solar Generator 1500W (3000W Peak) with 220W Solar Panel Included, 1548Wh LiFePO4 Power Station with 1500W AC Outlets, 100W USB Ports, 12V DC, for Home Electric Backup & RV/Van Camping
Price: $1,499.99 - $1,299.99
(as of Aug 14, 2024 06:45:28 UTC – Details)
CNET : One Of Best Tested Portable Power Stations in 2024 FlashSpeed 1500 portable power stationFlashSpeed 1500 portable power station
VTOMAN FlashSpeed 1500 Portable Power Station is the fastest charging product among more than 90 portable power stations tested by CNET experts.
If charging to recover your total capacity is a major concern for you, these are the units to look at.
LIFEBMS Expandable Capacity V-BEYOND TECHNOLOGY power supply solar generator,Protable powerstation,VTOMAN,Fast Starting Cars,outdoor generator, 1 SUPERSAFE LIFEBMS SYSTEM 2 EXPANDABLE ADD-ON BATTERY 3 V-BEYOND TECHNOLOGY 4 UPS 5 Restart Your Car Easily
portable power station 1500W AC INPUT 400W SOLAR INPUT 12V CAR CHARGING portable power station 1 MULTIPLE CHARGING METHODS 2 1500W AC CHARGING 3 400W SOLAR CHARGING 4 12V CAR CHARGING 5 POWER 12 DEVICES AT ONCE
VTOMAN Solar Generator (Solar Panel include) solar generator Vtoman solar panel IP67 Waterproof Easy Set-Up solar generator
portable power station FLAT TOP DESIGN NON-SLIP HANDLES TOP STORAGE BOX 1 5 Model LED Light 2 FLAT TOP DESIGN 3 DUAL NON-SLIP HANDLES 4 TOP STORAGE BOX
POWER FOR HOME APPLIANCES POWER FOR OFF-GRID LIFE POWER FOR PROFESSIONAL TOOLS 1 HOME BACKUP 2 OFF-GRID LIFE 3 PROFESSIONAL TOOLS
SPECIFICATIONS
Capacity 1548Wh (Expandable to 3096Wh) Battery Type LiFePO4(LFP) Battery AC Output 3x 110V~ 60Hz, 1500W (3000W Peak) USB-A Output 3x 5V-2.4A Quick Charge 3.0 Output 1x 18W, 5-3A, 9V-2A, 12V-1.5A USB-C Output 2x PD 100W, 5V-3A, 9V-3A, 12V-3A, 15V-3A, 20V-3A Car Output 1x 12V-10A DC Output 2x 12V-10A AC Input 100-130V, 1500W Max Anderson Input 30-60V, 400W Max DC Input 12-20V, 200W Max UPS Function Yes Pass-Through Charging Yes LED Flashlight 5 Modes (Weak/Medium/Strong/Strobe/SOS) Net Weight 41.5 lbs Dimensions 15.6″L x 10.5″W x 11″H
【Individual Shipments】 For the speedy arrival of your items, your Generator and Solar Panel will be dispatched independently. If you receive one item before the other, kindly await the arrival of the remaining item.
【SuperSafe LIFEBMS Power Station】LIFEBMS is a battery system by VTOMAN that provides up to 10 charging protections such as over-current protection and over-load protection to ensure safe charging in different environments. Besides,the built-in LiFePO4(Lithium iron phosphate battery) makes Vtoman power stations feature better heat-resistance and safer charging performance than NCM batteries.
【Capacity Expandable To 3096Wh】FlashSpeed 1500 power station has a battery capacity of 1548Wh that can meet your electricity needs for emergency backup power & outdoor camping. Besides, you have a choice of expanding the capacity from 1548Wh to 3096Wh with FlashSpeed 1500 Extra Battery(Sold separately) whenever you feel the capacity is not enough.
【V-Beyond Technology】Equipped with 1500W puse sine wave AC inverter, FlashSpeed 1500 can normally power devices below 1500 watts. Also with Vtoman’s V-Beyond technology, FlashSpeed 1500 can even run devices with rated power up to 3000 watts. (It’s primarily suitable for resistive loads such as lights, space heaters, toasters, ovens, and coffee makers.)
【Charge Up To 12 Devices Simultaneously】FlashSpeed 1500 battery station has 3x 1500W(Peak 3000W) AC outlets, 2x 12V/10A DC(5.5*2.1mm) output ports, 1x 12V/10A car cigarette lighter port, 3x USB-A ports and 2x PD100W USB-C port. It can charge up to 12 devices simultaneously, and supports pass-through charging.
【Multiple Charging Methods】VTOMAN FlashSpeed 1500 power station has 3 input ports, including 1500W AC input port, 400W Anderson input port and 200W DC input port. It takes only 1 hours to full charge when charging by wall outlet, and takes about 9-12 hours when charging by Vtoman VS220 Pro 220W solar panel through the Anderson input port.
【23% High Conversion Rate】Made of monocrystalline silicon solar cells, Vtoman VS220 Pro portable solar panel can absorb solar energy better with higher conversion efficiency that up to 23% than other conventional panels.
【Foldable & Portable】VTOMAN VS220 Pro solar panels can be folded into smaller sizes for easy portability, providing more flexibility for outdoor and off-grid use. VS220 Pro portable solar panel measures 26.4*23.7*2 inches when folded and weighs 19.5 lbs.
【IP67 Rating & Splash-proof】VTOMAN VS220 Pro solar panel features IP67 water-resistant rating that protects the panel from water splashing (Please DO NOT place it under the rain, or to soak in water).
