VTOMAN Jump 1000 Solar Generator with 220W Panels, 1408Wh Durable LiFePO4 (LFP) Battery Power Station with 1000W AC Outlet, Regulated 12V DC, 100W PD, for Home Backup & RV/Van Camping
Price: $279.98
(as of Aug 26, 2024 12:30:22 UTC – Details)
VTOMANVTOMAN
VTOMANVTOMAN
VTOMANVTOMAN
VTOMANVTOMAN
About Us
VTOMAN, a global leader in power sources, was founded by experts with 15 years in renewable energy, innovating sustainable solutions.
Mission & Vision
LifeBMS technology ensures safety and reliability in battery performance, reflecting our commitment to reliable, user-centric products.
Master New Energy Your Way
VTOMAN enables energy mastery with versatile power solutions from portable stations to solar panels for various lifestyles.
FAST-CHARGING POWER STATION
PORTABLE AND POWERFUL
HIGH CAPACITY POWER STATION
BUILD YOUR OWN SOLAR GENERATOR
EMBRACE THE POWER OF THE SUN
VTOMAN PORTABLE SOLAR PANEL
VTOMAN ADD-ON EXTRA BATTERY
VTOMANVTOMAN
【SuperSafe LIFEBMS Power Station】With LIFEBMS battery management system, VTOMAN power stations provide up to 10 charging protections, such as over-current protection, over-discharge protection, etc. Also, the built-in LiFePO4(LFP) battery makes VTOMAN power station feature better heat-resistance and safer charging performance than NCM batteries. VTOMAN solar panel is also built-in multiple protection system including over-current protection, over-load protection, short-circuit protection, etc.
【Multiple Charging Methods】VTOMAN Jump 1000 power station has 2x DC5521(5.5mm*2.1mm) input ports that supports 200W max input power. When charging with 2x VTOMAN 100W solar panels(Included in packaging), Jump 1000 can be fully recharged within 9-12 hours(under full sunlight). Except charging by solar panel, Jump 1000 power station can be also recharged by wall charger(about 7-8 hrs to full) and 12 car outlet(about 10-12 hrs to full).
【23% High Efficiency Solar Charging & Wide Compatibility】 VTOMAN foldable 19V/110W solar panel features 23% high conversion rate that can convert solar energy into electricity power more effectively than traditional panels. VTOMAN 220W panel is built-in 1x DC5521 output connector, 1x USB-A port(24W Max) and 1x Type-C port(45W Max), besides it also comes with 10 DC connectors of different size, which makes VTOMAN 100W panel compactible with most power stations and electronic devices.
【Pass Through Charging】VTOMAN Jump 1000 supports pass through charging, which enables you to use the output ports while charging the power stating by solar panel / AC charger / car charger. Also VTOMAN 1000 power station features a complete output ports including 3*110V/1000W AC outlets, 2*Regulated 12V/10A DC5521 output ports, 1*Regulated 12V/10A car cigarette lihter ports, 4*USB-A and 2*TYPE-C PD 100W output ports, which can charge up to 12 devices simultaneously.
【Expandable Capacity & Long-lasting LiFePO4】Jump 1500X LiFePO4 power station can expand its capacity from 828Wh to 2376Wh with Jump 1500 expansion battery(Sold separately) when you feel the capacity is not enough. Also the LiFePO4 cell inside Vtoman power station features 3,000 full cycles of lifespan before going down to 80% of its original capacity.
【1000W Constant-Power Supply】VTOMAN Jump 1000 battery generator can provide rated 1000W pure sine wave of AC power(Surge 2000W). In addition to powering devices below rated 1000 watts like most power stations do, Jump 1000 can also output constant 1000W power when powering over 1000W equipment instead of disconnecting the output. It provides an emergency solution when powering appliances over 1000W, such as water heaters.
【Regulated 12V DC Output & Multiple USB ports】VTOMAN 1000W battery station has 2x 12V/10A DC5521 output ports and 1x 12V/10A car cigarette lighter port(total 120W Max), perfect for powering device supports 12V DC input, such as car refrigerators, CPAP machines, portable tire inflator, etc. Also Jump 1000 has 2* PD 100W Type-C(USB-C) ports and 4* USB-A output ports(18W Max), great for powering electronics sush as smartphones, tablets, etc.
【Multiple Uses】VTOMAN power station helps to improve your quality of life in many ways. It works as a great emergency backup power if you live in a residential area that’s prone to frequent blackouts, a region that’s expecially vulnerable to hurricane, snowstorms, mountain fires, flood, volcanoes, drought, etc, then VTOMAN power station will be a wise investment for your home. Also VTOMAN power station provides much convenience on camping, RVs, family road trips, vehicle survival, etc.
【What’s In The Box】1*Jump 1000 portable power station,1*220W foldable solar panels, 1*MC4 to Anderson/XT60/DC5521 adapter, 1*AC charger, 1*Car charging cable, 1*User manuals.
【24-Month Warranty】VTOMAN attaches great importance to customer experience and provides 24 month warranty for VTOMAN power stations. Please feel free to contact us for any questions, we’ll usually reply within 12 hours.
