VTOMAN Jump 1000 Portable Power Station with Extra Battery, 1000W/2956Wh Durable LiFePO4 (LFP) Power Station with 1000W Constant-Power, Regulated 12V DC, PD 100W, for Home Backup & RV/Van Camping
Price: $2,249.99
(as of Aug 17, 2024 21:00:35 UTC – Details)
VTOMANVTOMAN
VTOMANVTOMAN
VTOMANVTOMAN
VTOMANVTOMAN
About Us
VTOMAN, a global leader in power sources, was founded by experts with 15 years in renewable energy, innovating sustainable solutions.
Mission & Vision
LifeBMS technology ensures safety and reliability in battery performance, reflecting our commitment to reliable, user-centric products.
Master New Energy Your Way
VTOMAN enables energy mastery with versatile power solutions from portable stations to solar panels for various lifestyles.
FAST-CHARGING POWER STATION
PORTABLE AND POWERFUL
HIGH CAPACITY POWER STATION
BUILD YOUR OWN SOLAR GENERATOR
EMBRACE THE POWER OF THE SUN
VTOMAN PORTABLE SOLAR PANEL
VTOMAN ADD-ON EXTRA BATTERY
VTOMANVTOMAN
【2956Wh Huge Capacity】By connecting with Jump 1500 extra expansion battery(Included), Jump 1000 LiFePO4 power station can expand its capacity from 1408Wh to 2956Wh. Also the LiFePO4(LFP) battery inside Vtoman power station features 3,000 full cycles of lifespan before down to 80% of its original capacity. It provides you enough power and long-lasting battery life to meet the demand for your daily power needs.
【SuperSafe LIFEBMS Power Station】VTOMAN battery power stations are built-in a super safe LIFEBMS battery management system that provides up to 10 battery protections for safe charging, including over-voltage protection, over-current protection, over-charge protection, over-discharge protection, etc. Also thanks to the built-in LiFePO4, Vtoman power station is more heat-resistant and safer than most NCM batteries.
【1000W Constant-Power Supply】VTOMAN Jump 1000 power station can provide pure sine wave 1000 watts of rated AC power(Surge 2000W). In addition to powering devices below rated 1000 watts like most power stations do, Jump 1000 can also provide constant 1000W power when powering over 1000W appliances instead of turning off the output. It provides you an emergency solution when powering appliances over 1000W, such as water heaters, space heaters, ovens, etc.
【Pass Through Charging】VTOMAN 1000 power station features 12 output ports including 3*110V/1000W AC outlets, 2*Regulated 12V/10A DC5521 output ports, 1*Regulated 12V/10A car cigarette lihter ports, 4*USB-A and 2*TYPE-C PD100W output ports. It supports pass through charging, which enables you to use the output ports while the power station gets charged. It can charge up to 12 devices simultaneously, enough to power most of your electric devices and save the space on wall!
【Regulated 12V DC Output】VTOMAN 1000W battery powered generator has 2x 12V/10A DC5521 output ports and 1x 12V/10A car cigarette lighter port(total 120W Max). All the DC output is with regulated 12V voltage, which is perfect for powering device and equipment that support charging by 12V DC input, such as car refrigerators, CPAP machines, portable tire inflator, etc.
【Dual PD 100W Type-C Output】PD 100W Type-C port is great for powering laptops. VTOMAN Jump 1000 is equipped with two PD 100W Type-C(USB-C) ports(total 200W) and four USB-A output ports. The USB-A ports also include a QC 3.0 fast charge port that can output 18W max, suitable for powering electric device sush as smartphones, tablets, etc.
【HOW TO RECHARGE】To charge the expansion battery, first connect Vtoman expansion battery to Jump 1000 power station via the CP3500 cable coming in the packaging; Then connect the AC Adapter & Car Charger & Solar Panels to Jump 1000 power station to recharge the expansion battery.
【Multiple Uses】VTOMAN power station helps to improve your quality of life in many ways. Firstly it works as a great emergency backup power if you live in a residential area that’s prone to frequent blackouts, a region that’s expecially vulnerable to hurricane, snowstorms, mountain fires, flood, volcanoes, drought, etc, then VTOMAN power station will be a wise investment for your home. Also VTOMAN power station provides much convenience on camping, RVs, family road trips, vehicle survival, etc.
【What’s In The Box】1*Jump 1000 portable power station, 1*Jump 1500 expansion battery, 1*AC charger, 1*Car charging cable, 2*USB cables, 1*CP3500 cable, 1*User guide.
【24-Month Warranty】VTOMAN attaches great importance to customer experience and provides 24 month warranty for VTOMAN power stations. Please feel free to contact us for any questions, we’ll usually reply within 12 hours.
