Price: $219.99 - $199.99
(as of Jul 25, 2024 01:00:17 UTC – Details)
Specifications
Model T3 Truck Camera LCD Screen 3.0 inch Video Resolution Front camera1080P; Side camera 720P View Angle 140° for main camera; 120° for side camera Night Vision Support, 4pcs IR LED light for side cameras Lens Waterproof IP67 WiFi App Support GPS Track Support Mic/Speaker Built-in Loop Recording 1/3/5 minutes G-Sensor Built-in Video Format MOV (H.264) Memory Card Supports 1 maximum 256G MicroSD card (not included)
High-Definition CMOS
The main camera has a CMOS sensor with 1080P resolution, while the two separate cameras have 720P resolution. A 3.0″ LCD screen makes it easy to monitor real-time recording and playback footage instantly.
3 Camera Simultaneously Recording
The T3 truck camcorder allows you to record from 3 different angles at the same time. The main camera looks forward to recording what is happening in front of you, and the other 2 separate cameras look to the side or rear to help you avoid blind spots.
Waterproof & Night Vision & Wide Angle
IP67 Waterproof/rainproof: Record every moment you drive, whether it is raining or snowing.IR Night Vision: The built-in 4 pieces of IR LED light, help you to capture clear images at night.Wide Angle: The wide-angle lens captures a perfect wide-angle view from 3 points of view, making it easier for you to drive safely.
Easy Camera Switching
Split-Screen: Supports single full screen, 2 split screen(side by side), and 3 split screen(PIP) display modes.
2.4G Remote: Easily switch between cameras using the wireless remote control.
Auto-Triggered Detection: Automatically switch to the corresponding camera according to the turning light signal.
Seamless Loop Recording & G-Sensor
With loop recording enabled, drivers will have the option to record videos in loops of 1/3/5 minute video files. When the SD card is full, the oldest video will be overwritten.
Built-in G-Sensor will be activated when detecting a collision, the truck dash cam will automatically enter emergency mode, and Video files recorded in emergency mode are protected from being overwritten.
WiFi Connection
Connect dashboard cameras to mobile phones via the built-in WiFi. Use the free APP to live preview, playback, and download videos at any time.
Included in the package:
• 1 x Monitor(built-in main camera)
• 2 x Cameras and extension cables(19.6ft)
• 1 x Suction cup mount
• 1 x Power cable
• 1 x 2.4G remote
3.4 out of 5 stars
44
3.4 out of 5 stars
44
3.9 out of 5 stars
7
3.9 out of 5 stars
7
9
3.5 out of 5 stars
33
$199.99$199.99 $199.99$199.99 $209.99$209.99 $209.99$209.99 $219.99$219.99 $269.99$269.99
Channel
3CH 3CH 3CH 3CH 4CH 4CH
Simultaneously Recorded Channels
3CH 3CH 3CH 3CH 2CH 4CH
Monitor
3.0” 3.0” 4.5” 4.5” 7.0” 7.0”
Video resolution
1080P+720P+720P 1080P+720P+720P 1080P+720P+720P 1080P+720P+720P 1080P+1080P+1080P+1080P 1080P+1080P+1080P+1080P
Integrated camera on Monitor
Front Front Front / / /
Camera cable length
20/20 ft 20/20 ft 20/20 ft 7/20/20 ft 7/20/20/49 ft 7/20/20/49 ft
IR Night Vison
Left/Right Left/Right Left/Right Left/Right Left/Right/Rear Left/Right/Rear
WiFi
GPS track
Memory card support
256GB x 1 256GB x 1 256GB x 1 256GB x 1 256GB x 1 256GB x 2
🚚【3 Cameras Recording & 1/2/3 Split Screen】The T3 truck dash cam allows for simultaneous recording from three different angles. One 1080P camera for front, and the other 2 separated 720P cameras for side or rear view, you can easily monitor your truck’s surroundings. Truck monitoring split-screen modes can be switched to either single full view or multi-split screen(up to 3).
🚚【IP67 Waterproof and Infrared Night Vision】 The truck recorder features IP67 waterproof resistance lenses, ensuring optimal functionality in any weather conditions. The built-in 4 pieces of IR LED lights provide reliable infrared night vision, enabling you to capture clear images even in low-light environments.
🚚【Loop Recording & G-Sensor】This dashboard camera supports up to a maximum of 256GB MicroSD card. With loop recording enabled, you have the flexibility to choose between 1, 3, or 5-minute video files. Once the memory card is full, the oldest video file will be overwritten automatically for continuous recording. In case of a collision, the built-in G-Sensor will activate the dash cam’s emergency mode. All video files recorded during emergency mode will be protected from being overwritten.
🚚【Wireless Control and Auto-Triggered Camera Switch】Connect the yellow wire of the separated cameras to the turning or reverse trigger wire of your vehicle, this will enable the monitor to display the corresponding cameras automatically when the turning or reversing signal is detected. Alternatively, you can also easily switch between camera displays manually using the attached 2.4G wireless remote, giving you full control at your fingertips.
🚚【Smart WiFi Connection and Convenient Power Supply】Enhance your driving experience with the built-in WiFi and free app, allowing you to connect the dashcam to your smartphone effortlessly. Simply plug the device into your vehicle’s cigarette lighter power socket to convert the 9~24V DC power source to a 5V/2A supply for the DVR. It’s the perfect addition for all types of vehicles, including cars, trucks, vans, trailers, buses, and more.
⭐【Lifetime After-Sales Support 】VSYSTO is a remarkable company and believes in driving innovation to add value for our customers. We offer lifetime after-sales support for this 3ch semi truck dash camera. If you have any questions about this dash cam recorder, please contact our customer service team.
