VSYSTO 3CH Truck Dash Camera DVR 4.5” Monitor with WiFi GPS and Waterproof Backup Video Recorder- 1080P HD Front, Sides, and Rear View Security Infrared Night Vision Cameras for Truck RV Trailer Van
Price: $209.99
(as of Jul 29, 2024 23:45:17 UTC – Details)
dash cam for truckersdash cam for truckers
VSYSTO Backup Camera for Trucks (3cameras-front,rear/sides)
Model T4.5 Truck Camera LCD Screen 4.5 inch Video Resolution Front camera1080P; Side camera 720P View Angle 140° for main camera; 120° for side camera Night Vision Support, 4 pcs IR LED light Video Format MOV (H.264) Memory Card Support single micro SD card (maximum 256G; Class 10; not include) Loop Recording 1/3/5 minutes Microphone Built-in (main camera) G-Sensor Support GPS Module Support Operation Temperature -10~+65°C Waterproof Cameras IP67 Side Camera Wire Length 19.7 ft for each
 dash cam for trucks. dash cam for trucks.
dash cam for truckers side camera for carsdash cam for truckers side camera for cars
 vehical backup camera vehical backup camera
4.5” LCD IPS Screen Monitor
Having a 4.5” LCD makes it very convenient to monitor the real-time footage, and playback the recorded video immediately. The 480X854 HD monitor provides a super clear image from the front backup side camera view.
3 Camera Simultaneous Recording
T4.5 trucker dash cam allows for simultaneous recording from 3 different angles. The Main Camera faces forward to record everything that happens in front of you, and the other 2 separate cameras for side or rear view to help you avoid blind spots.
IP67 Waterproof and Super Night Vision
IP67 Waterproof/rainproof: Record every moment of your driving whether it is rainy or snowy.
IR Night Vision: The built-in 4-piece IR LED light, helps you capture a clear image at night.
wireless backup camerawireless backup camera
 video recorder for truck video recorder for truck
dash cam for truckers semi truckdash cam for truckers semi truck
Emergency Recording Mode
Built-in G-Sensor, vehicle dash cam will automatically activate emergency recording mode when detecting a collision. Video files recorded in emergency mode are protected from being overwritten.
Seamless Loop Recording
With loop recording enabled, drivers will have the option to record videos in loops of 1/3/5 minute video files. When the SD card is full, the oldest video will be overwritten.
GPS Tracking with speed
With Built-in GPS, the truck dash cam accurately tracks your driving location and speed. You can playback the video files on the Google Map on computer, a simultaneous Google map view will show location, driving route, and driving speed.
 TRUCK DASH CAM TRUCK DASH CAM
security camera for truckssecurity camera for trucks
Triple-Camera Setup & Split Screen Display: The T4.5 truck camera enables simultaneous audio and video recording from 3 different angles–one for the front and two for side or rear views. The 19.7ft-long cables make it easy to install the two independent cameras anywhere, ensuring 360-degree security coverage with no blind spots. The reversing system effortlessly switches between full view, split screens, and PIP, ideal for 9V-30V Semi-trucks, RVs, Trailers, Pickups, Campers, and Buses.
Waterproof Design & Enhanced Night Vision: The main camera features a full HD 1080P CMOS sensor integrated into the monitor, while the two separate cameras have HD resolution and come equipped with a 4-piece powerful IR LED light for clear image capture during nighttime, ensuring reliable surveillance. With an IP67 waterproof rating for the cameras and IP65 for the connection cables, the T4.5 semi-truck camera recorder is well-suited for use in any weather conditions.
Free WiFi App and GPS Tracking: Seamlessly link to the vehicle DVR using the WiFi app on your smartphone, enhancing your driving experience with wireless real-time preview and video management. Moreover, the included GPS tracker monitors speed, coordinates, and atmospheric pressure directly on the 4.5-inch HD monitor and enables route playback through the WiFi app, offering valuable insights for drivers and enhancing overall road safety.
Wireless Control and Auto-Triggered Camera Switch: Connect the yellow wire of the separated cameras to the turning or reverse trigger wire of your vehicle, this will enable the monitor to display the corresponding cameras automatically when the turning or reversing signal is detected. Alternatively, you can also easily switch between camera displays manually using the attached 2.4G wireless remote, giving you full control at your fingertips.
Loop Recording & Emergency Mode: The 3-Channel Camera System supports up to a 256GB MicroSD card (not included) for extensive recording. Loop recording automatically overwrites the oldest video files in 1/2/3/5 minute clips, ensuring continuous recording when the SD card is full. The system also features an emergency recording mode triggered by the G-sensor or manual activation, protecting important videos from being overwritten. Preserves valuable evidence in disputes and insurance claims.
