Price: $142.89
(as of Sep 29, 2024 20:30:18 UTC – Details)
【POWERFUL 1000W BRUSHLESS MOTOR】-The 48V 1000W Ebike Rear Wheel Conversion Kit features a powerful brushless gearless hub motor. It runs efficiently and quietly. The max speed can reach 28mph (45km/h). It universal fits any 26IN bike frame with 3.94IN/100mm front fork dropout.
【SAFE & DURABLE】-CE, EN15194 approved, ensures safety and quality. Motor power cut-off function of the brake levers prevent the motor from overheating and saving energy. Smoother bearing & 27mm Magnet Steel used in the Hub Motor, ride further with our Ebike Kit.
【POWER DISPLAY INTEGRATED ON THROTTLE】-The twist throttle ensures speed control is fast and simple, and power display integrated on it, takes less handlebar space. The aluminum alloy double wall rim is durable and stable, it can hold up to 330lbs/150kg.
【Road-legal Ebike Conversion Kit】-Restricted to 750W and 24mph (38km/h) speed by default as a road-legal electric bike conversion kit, but you could also switch into 1000W full power output for off-road mode by simply disconnect the blue cable, would brings 28mph (45km/h) speed.
【PEDAL ASSIST SYSTEM】The PAS function of this e bike conversion kit allows you to switch 3 riding modes between Throttle / PAS / Manual. The suitable riding mode can be switched as needed. Less fatigue and more comfortably, great for long trips. Equipped detailed assembly instruction and video,7 X 24H customer service, help you complete the assembly easily.
