VEVOR Tripod Projector Screen with Stand 60 inch 16:9 4K HD Projection Screen Stand Wrinkle-Free Height Adjustable Portable Screen for Projector Indoor & Outdoor for Movie, Home Cinema, Gaming, Office
Price: $68.05
(as of Aug 15, 2024 23:30:29 UTC – Details)
16:9 4K HD Projector Screen
With the 4K HD visual quality and 16:9 aspect ratio, this portable movie screen creates an immersive experience for you. In addition, the screen is made of premium polyester fiber, wrinkle-free, and easy to clean.
160-Degree Viewing Angle
The 60 inch projection screen features a 160-degree viewing angle, ensuring clear projection images from different audience viewing directions. Besides, due to its large screen, there is no resolution loss from any angle.
Adjustable Aluminum Tripod
The tripod stand, built with sturdy aluminum alloy, provides exceptional stability and support to the portable projector screen. And you can adjust the height within 78.7″-98.4″/200-250 cm for a better viewing effect.
Effortless & Quick Installation
Designed for easy setup, this screen projector with stand takes only a few steps to assemble, no need for any tools. A weighted bag, yard stakes, and ropes are offered for extra stability when used outdoors.
Lightweight & Portable
The upper and lower frames can be folded into four sections respectively, neatly stored in a carrying bag with other parts. This movie screen with stand weighs just 14.3 lbs/6.5 kg, easily carried to backyard or auditorium.
Indoor & Outdoor Use
Our brilliant projection screen is the most compact and travel-friendly option for indoor and outdoor projection. It is perfect for home cinema, business meetings, weddings, classroom training, outside camping, etc.
Specifications
Model: DM-ABS-60
Screen Material: Polyester
Tripod Material: Aluminum Alloy
Diagonal: 60″/152.4 cm
Aspect Ratio: 16:9
Screen Resolution: 4K HD
Viewing Angle: 160 degrees
Stand Type: Tripod
Image Area (W x H): 52.4″ x 29.9″/133 x 76 cm
Stand Height: 78.7″-98.4″/200-250 cm (adjustable)
4K HD Vivid Imagery: The projection screen tripod brings you vivid imagery and impeccable viewing experience with a 16:9 4K ultra HD resolution. The polyester screen provides an outstanding image reproduction due to its wrinkle-free surface. Four black side borders are designed to enhance picture contrast.
Wide-angle Screen: With the 60″/152.4 cm diagonal display area, the projection screen with stand allows more people to enjoy blockbusters together. 160-degree wide viewing angle means you will have no glare or lumen loss while diffusing light in all directions, even in a well lite office.
Height Adjustment: Our projector stand screen is outfitted with an aluminum tripod stand, ensuring stability on all types of flooring. Its legs are foldable for easy storage. The stand height is adjustable from 78.7″/200 cm to 98.4″-250 cm by turning the knobs for your comfort experience.
Portable & Easy Setup: Whether it is a conference or sudden movie planning at home, the projector screen and stand are quick and easy to set up. No tools, hardware, or special expertise are required. Coming with a portable storage bag, you can get a phenomenal viewing experience at any time anywhere.
Wide Application: Suitable for most projectors, this portable projector screen with stand is a perfect mobile projection solution for professional or personal needs. You can turn any place into a home theater or media room, enjoying movies, sports events, photos, video games, and giving presentations.
