VEVOR 12 Volt Refrigerator Qt, Dual Zone Car Fridge Freezer w/App Control & Wheels 12/24V DC & 110-240V AC Electric Compressor Cooler for Truck Vehicle RV Boat Outdoor & Home Use, 38 Quart, Grey
Price: $201.73
(as of Aug 19, 2024 19:45:11 UTC – Details)
key Features
Dual Zone Refrigerator
The inner space is divided into 2 parts – the freezing and refrigeration area. Internal dimensions: 20.4 x 10.5 x 10.7 inches, allowing you to place drinks upright below 10.7 inches in height. And 38 quart is a perfect size for going out to join outdoor parties, picnics, camping, or road trips.
Fast Cooling
Our car refrigerator has a fast cooling speed and can quickly drop from 20℃ to 0℃ in 15 minutes. And it can last for 10 hours after the power supply has been cut off, so you can enjoy delicious and fresh food during the journey.
Precise Control
The onboard refrigerator can regulate the temperature and mode through the digital panel, so you can monitor the temperature and power at any time. You can also use the mobile app to control the temperature and charge with a USB socket.
Stability While Driving
The three-layer battery protection can prevent the refrigerator from depleting the vehicle’s battery. It is designed to be low noise and ensure you a good sleep after driving for a long time. The fridge can also be kept stable by tilting 45°.
Designed with You in Mind
Our car refrigerator has many considerate details. The frosted material improves the hardness and durability, the built-in LED light allows you to see the inside of the refrigerator. In addition, the smooth roller and the handle improve portability, and the drain hole avoids ponding when in use.
Wide Application
Operating at 12 / 24V DC and 110-240 AC, the 12V refrigerator freezer can be connected to an automobile cigarette lighter and household power supply. Our portable compressor refrigerator is suitable for RV trips, campsites, boats, camping, fishing, road travel, and other outdoor activities.
Specifications
Model: T36
Capacity: 36L / 38 Quart
Power: 80W
Cooling Range: -20℃ – 20℃/-4℉- 68℉
Voltage: 12/24V(DC), 100-240V(AC)
Power Consumption: 0.2kw.h/24h
Noise Level:
Dual Zone & Temperature: Our car refrigerator has a cooler area and a frozen area for you to store different kinds of food(The temperature on the left must be higher than that on the right). The touch screen offers a simple and intuitive control experience, showing the current temperature of the cooler and freezer, which is adjustable. You can also use the mobile app to control its temperature. The temperature can be controlled separately in both areas.
Efficient Refrigeration: With compressor refrigeration technology, this 12V car freezer can achieve fast cooling from 68℉/20℃ to 32℉/0℃ in 15 minutes.After 90 minutes, the internal temperature of the refrigerator can be as low as -4 ℉/-20℃. There are two modes for you to choose from: the ECO mode for energy-saving efficiency or the MAX mode for fast cooling.
Perfect Structure: Our car refrigerator is made of frosted material, which is tough, durable, and wear-resistant. The smooth roller makes it easy for you to move the refrigerator. The internal LED lamp allows you to observe the interior more clearly, the detachable partition allows you to choose between single zone and double zone.and the drainage hole discharges the accumulated water inside. Besides, we also provide a charging interface to charge your mobile phone.
Secure Driving: Our car fridge is equipped with 120/240V AC and 12/24V DC adapters, so you can move the camping fridge seamlessly from home to vehicle. The three-layer battery protection can keep the refrigerator from depleting the vehicle’s battery. It is designed to produce low noise and ensures you will sleep well after driving for a long time. The fridge is even stable when tilting 45°.
Extensive Usage: This 38Qt fridge freezer will fit snugly in your trunk, behind a car seat, or in the bed of a truck. You can take a 12V compressor fridge to any outdoor activity without worrying about bumpy roads or inclines. The car’s travel fridge is perfect for RVs, campsites, boats, camping, fishing, road trips, and other outdoor activities.
