Verizon Wireless Jetpack Netgear AC791L | Unlocked Device | 4G Mobile WiFi Hotspot | LTE Cat6 speed Up to 300 Mbps | Usage Up to 20 hours | Portable Travel Router | EVDO-LINK Bundle – Verizon Sim Card
Price: $104.99
(as of Sep 12, 2024 17:45:18 UTC – Details)
All-Day, Premium WiFi Performance The Verizon Jetpack 4G LTE mobile hotspot from NETGEAR packs ultimate power and performance in one device for fast, reliable WiFi on-the-go – even when traveling internationally. Simply power it on and connect your laptop, tablet, or WiFi-enabled device to email clients, video chat with family, or access files in the cloud seamlessly. It’s secure, easy-to-use, and designed with an incredible battery life of up to 24 hours – making this the ideal travel companion for work or pleasure. Highlighted Features: Enhanced Download Speeds: LTE Category 6 with 2X Carrier Aggregation offers optimal download speeds of up to 40 MHz. Extended Usage: Powerful 4340 mAh battery that lasts up to 10 hours of continuous use 802.11ac/b/g/n and simultaneous dual-band WiFi capability for the ideal mix of range and performance Travel Without Boundaries: With Global-ReadyTM, keep your devices connected in over 200 countries worldwide. Universal Charging (Jump Boost): This is not just a hotspot, use it to power up your smartphones and other USB devices on the go. Top-notch Security: Comes equipped with Guest WiFi, password protection, and the latest WiFi security standards. Multiple Device Connectivity: Link up to 15 WiFi-enabled devices. Whether you’re on a business trip or a family vacation, everyone stays connected without the need for public WiFi. User-Friendly Interface: Features a vibrant 1.77” LCD with touch navigation buttons, keeping you updated on data usage, network status, and more. Enhanced Signal: Two TS-9 ports are available for optional 4G/3G antennas to bolster connectivity. Effortless Management: Handle your hotspot settings conveniently with the free NETGEAR AirCard App available for both tablets and smartphones. Experience the future of connectivity today with the Verizon Jetpack 4G LTE Mobile Hotspot by NETGEAR. Perfect for those always on the move.
************************************* Need to Buy Your own Data Plan *************************************
DOES THIS DEVICE NEED A SIM CARD: Yes, this device requires an activated SIM card to be used with it. This hot spot mifi device is unlocked for use with various carriers worldwide. However, it is essential to check with your preferred carrier to ensure compatibility with their network frequencies and services.
WHAT NETWORK FREQUENCIES ARE SUPPORTED BY THIS DEVICE: The Jetpack AC791L is compatible with a range of network frequencies and can be used with different carriers, both domestically and internationally, including LTE Bands 2, 3, 4, 7, and 13. It is equipped with global roaming capabilities but always confirm it with your network provider to ensure functionality.
WHAT CAN I EXPECT OUT OF THE BOX: Out of the box you get the device equipped with two 4,340mAh batteries (stock & extra), soft case, wall charger with USB Cable and Verizon card (separate activation & data plan required).
WHAT DOES UNLOCKED REALLY MEAN: While this device is unlocked and can be used with different carriers, it still requires a separate plan for use either domestically or internationally. Be sure to check with your carrier about the need for any specific plan or activation details.
SPECIAL FEATURES TO NOTE: LTE Advanced Carrier Aggregation for enhanced speeds​​, Global-Ready for over 200 countries​​, connects up to 15 Wi-Fi devices​​, 1.77-inch LCD display, durable and travel-friendly design​​, Dual-Band Wi-Fi with 2×2 MIMO technology​​, and TS-9 connectors for external antennas​​.
Verizon sim card included BUT you need to buy your own data plan!
