Vekooto Magnetic Solar Wireless Backup Camera, Upgrade Auto On/Off Camera, 5-inch Monitor, HD 1080P Trailer Hitch Rear View Cam, Rechargeable RV Backup Camera Wireless System for Truck RV Car
Price: $179.99 - $119.99
(as of Aug 10, 2024 14:30:13 UTC – Details)
VEKOOTO Upgraded 30-DAYS* STANDBY Magnetic Solar Wireless Backup Camera System 低功耗SW5低功耗SW5
Upgrade and Upgrade: The backup camera uses proprietary R&D tech for automatic sleep/activity switching, achieving a 30-Days* standby.
*Assuming the monitor’s power is off after using the camera for 30 minutes daily, enabling continuous usage and standby for 30 days. (Camera fully charged)
No Wiring No Drilling! Easy to Install! 低功耗SW5低功耗SW5 How to install magnetic backup camera?
The camera’s magnetic base allows it to stick to vehicles. You can attach it to the back of your trailer, observe a tow hitch on your truck, place it inside a horse trailer to monitor horses, or use it to watch over the entrance of your RV. (Non-metallic vehicles can use the included metal plate.)
SW5低功耗SW5低功耗 How to install the monitor?
Plug and Play: Connect the power cord to the monitor and power it through the 12V power interface (cigarette lighter). The power button on the power connector allows for quick on/off control of the monitor.
The package includes a gasket, when used with the suction cup mount, enhances its stability.
低功耗SW5 低功耗SW5
*Second Camera Requires Separate Purchase
低功耗SW5
In complete darkness, Infrared night vision is your great companion.
低功耗SW5
Can turn on/off guidelines and adjust their length, width, and height.
低功耗SW7-1
1 Stronger Signal 2 2 Split Screen 3 IR Night Vision 4 DIY Guidelines 5 Temperature
低功耗SW5低功耗SW5 Wide Angle
The 150-degree wide viewing angle will not make the picture excessively curved, making it easier to judge distances. 低功耗SW5低功耗SW5 IP69K Waterproof
Waterproof magnetic backup camera that works perfectly in all weather. 低功耗SW5低功耗SW5 5-inch Monitor
Equipped with a suction cup bracket and a dedicated base, it will not move easily whether you install it on the windshield or on the dashboard. 低功耗SW5低功耗SW5 Image Flip
The image adjustment function can adapt to your various usage scenarios.
低功耗SW5低功耗SW5
Remotely turn off/on the backup camera.
Not Just a Backup Camera, But Also Your Good Assistant 低功耗SW5低功耗SW5
Plug-and-play functionality is at the core of our design for this magnetic backup camera system, eliminating the need for intricate wiring. Its portable design lets you place the camera anywhere you want with ease.
11
1-Minute Installation: The magnetic base of our wireless backup camera ensures a hassle-free setup, taking merely a minute! Our trailer backup camera ensures stable signals up to 50ft. Perfect for various vehicles such as trucks/pickups/cars/campers/RVs/horse trailers/5th.
Remote Control Camera on/off: VEKOOTO’s wireless backup camera synchronizes with the monitor, effortlessly turning on and off without manual intervention. When the monitor power off, the rearview camera enters a sleep mode, reducing power consumption by a staggering 99.97%.
Waterproof & IR Night Vision: Upgraded magnetic backup camera with a very high IP69 waterproof rating and 9 infrared night vision lights to send HD true videos and images. Trailer backup camera wireless boasts uses 6 glass lenses to make the picture more realistic and clear.
2 Channels & DIY Guidelines: Vekooto’s back up camera for truck. rv can add a second rear camera to reduce the blind spot in driving and make travel safer. Also, you can adjust the guidelines according to your preferences.
High Energy Density Rechargeable Battery: Wireless backup camera for trucks built-in 3 18650 series lithium batteries with a total capacity of 9600mAh. A full charge can allow the camera to work for more than 15 hours, which is enough for long-distance travel. (When the camera is not in use, cut off the monitor power to make the camera standby longer)
Quality Assurance & Support: We stand by our product’s quality. With a lifetime of technical-support, a 2-year replacement service, and a 30-day money-back guarantee, Vekooto ensures your satisfaction.
