VEKOOTO Magnetic Solar Wireless Backup Camera 7” Monitor, 1080P Hitch Backup Camera, Battery and Solar Powered Trailer Rear View Cam for Boat Travel Trailer Gooseneck Horse/RV/5TH/Reverse (SW7-1)
Price: $79.99
(as of Sep 08, 2024 04:15:16 UTC – Details)
Vekooto Wireless Magnetic Solar Backup Camera 7” Monitor Kit For RV/Trailer etc sw7-1sw7-1
**The camera will not turn off and on synchronously with the monitor, and you need to manually power off the camera to save camera power.
Upgraded version camera system, the camera can automatically turn on/off in sync with the monitor, please purchase ASIN: B0CVWTK8LX
Integrated Magnetic Base and Built-in Battery, Truly Wireless SW5SW5
After testing, if the backup camera is exposed to full sunlight, the camera can work for up to 18 hours!
SW7-1 7‘’太阳能
SW7-1 sw7-1 S01 S01 1
1 WATERPROOF
2 7” MONITOR
3 TEMPERATURE RESISTANCE
4 NO DELAY
5 150° WIDE ANGLE
Specifications of the Wireless Magnetic Backup Camera
Monitor Size 7 Inch Effective pixels 1920*1080 pixels Camera Battery Capacity 9600mAh Camera Battery Charging Time USB 5V 2A/ 6H Camera Working Time Daytime/20H Night Vision/13H Viewing Angle 150° Signal Transmission Range Unobstructed space: 328ft, On vehicle: 66ft Waterproof Rating IP69K Loop Recording Support Image Device 1/3″ CMOS Mounting Type Windshield Mount/Dashboard Mount Power Plug Cigarette lighter Plug and Play Material Black Aluminium Alloy Operation Temperature -20°C ~ 80°C;RH95%MAX Spread Spectrum FHSS Applications Suitable for all types of vehicles, including pickup trucks, cars, vans, RVs, trailers, tractors, horse trailers, forklifts, and more.(Vehicle length is less than 70 feet.)
11
Wireless Backup Camera System We Recommend
4.0 out of 5 stars
247
3.7 out of 5 stars
63
3.7 out of 5 stars
118
3.7 out of 5 stars
118
$79.99$79.99
Monitor Size
5-inch
phone as monitor
7-inch
7-inch
Recording
Camera
1
1
2
1
66ft (on vehicles)
30ft (on vehicles)
66ft (on vehicles)
66ft (on vehicles)
Guidelines
Wireless
Easy Magnetic Mounting: The wireless backup camera effortlessly attach to any metal surface with a high-strength magnetic base. No additional hardware needed. The magnetic backup camera design also makes it convenient to remove and re-install wireless reverse camera on another vehicle or location.
Rechargeable Battery & Solar Assist: Built in a 9600mAh battery, SW7 wireless backup camera for trucks can work continuously for a long time. 100% wireless, no need extra power supply, please use a 5V phone charger and USB C power cord to charge the SW7 magnetic backup camera wireless.
DVR Loop Recording: Back up camera system built-in recording system automatically overwrites old footage to keep recordings refreshed. In the event of an accident or impact, the system automatically protects that video segment for your use later. This can be saved on the included 32G memory card. (expandable to 128GB)
Strong Stable Signal: Using the latest digital chip, SW7 wireless backup camera for trailer boasts a 328ft digital wireless range within vehicle. The trailer backup camera wireless perfect for jeep truck/pickup/car/camper/voyager RV/horse trailer/fifth wheel/SUV/van/tractor/boat ect.
Quick DIY Installation: Get set up in just 3 minutes. No complex wiring or mechanical skills required, saving you time and installation costs. Monitor Plug and Play and easily attach the Magnetic Wireless Backup Camera to any metal surface of the vehicle.
HD 1080P Image & Super Night Vision: The SW7 wireless trailer camera kit is equipped with IR LEDS and an auto light sensor, which provides an HD view in the darkest night without any ambient light. The rubberized base material is designed to prevent scratching the car paint when installing the SW7 truck backup camera.
**The camera will not turn off and on synchronously with the monitor, and you need to manually power off the camera to save camera power. Upgraded version camera system, the camera can automatically turn on/off in sync with the monitor, please purchase ASIN: B0CVWTK8LX
