Price: $16.99
(as of Sep 16, 2024 05:45:47 UTC – Details)
Urgrette 3 in 1 Wood Grain Pipe Lighter—Perfect for Pipe Lover
The video showcases the product in use.The video guides you through product setup.The video compares multiple products.The video shows the product being unpacked.
Are you looking for a pipe lighter that fits perfectly with the color of your pipe?Do you want to find a wonderful gift for family or friends?
>>>This Urgrette 3 in 1 wood grain pipe lighter is here!
Slim & Compact & Sleek
wood grain paint0.9 x 1.5 x 0.5 inch/0.15 lbeasy-to-carry: Storing in the pocket for on-the-go use. 3 in 1 Foldable Pipe Gadgets
Scraper: scrape off dust on the pipe.Picking Stick: clear ash.Tamper: flatten pipe, help to burn. Easy to Adjust Flame Size
Select a correct screwdriver.Rotate the adjustment lever.Raise or reduce flame length.
Equipped with Piezo ignition. Save flints and wicks.A 45° soft flame, directed for precise lighting.
1 Nice Appearance
2 3 Pipe Tools
3 Adjustable Gas Valve
4 Piezo Ignition&Soft Flame
Step 1
KEY POINT : Choose any butane gas brand that has the long universal filling tip.
Step 2
Push filling hole to release airShake gas can some times to warmInsert gas can tip.Push it 2-3 times Step 3
After refilling, use it after 10 mins (gas need time to stabilize)Do not ignite it more than 15 secs
How to Refill It?
1 Choose Right Gas Can 2 How to Refill it ? 3 How to Use it ?
Perfect for Different Occasions Daily Use
For Cleaning
For Candle
For Pipe
Urgrette Pipe Lighter with Nice Gift Box Warning and Tips:
Keep away from children. Keep away from face and clothing when lighting a lighter.Do not expose to heat or sunlight for long periods of time..Do not puncture or put in fire. Be sure flame is out after using.Do not ignite the lighter for long time ( no more than 15 seconds )Make sure there is no fire nearby when refueling.
Other Choices in Urgrette Adjustable
Refillable
Windproof
Gas Window
Flame Type Blue Jet Flame Blue Jet Flame Blue Jet Flame Blue Jet Flame Blue Jet Flame Blue Jet Flame
WOOD GRAIN PAINT: The imitation wood grain design of our butane lighter makes it look stylish and matches pipe perfectly. NOTE: ALL LIGHTERS ARE SHIPPED UNFILLED. PLEASE FILL WITH FUEL BEFORE USE
PROFESSIONAL 3 IN 1 PIPE LIGHTER: This pipe lighter has 3 foldable pipe gadgets, including tamper, scraper and picking stick. These tools can easily clean your pipe very well like removing soot and residue. It is perfect for pipe lovers
45 DEGREE ANGLED SOFT FLAME: Urgrette pipe lighter produces a soft flame at a 45° angle, and the impulse of the flame is not too strong, will not wash away the things in the pipe. The temperature of the flame is about 930°F, can toast slowly without burning your fingers
REFILLABLE & ADJUSTABLE: This pipe lighter is refilled with butane gas(long tip canister). The flame size can be changed by rotating the flame valve lever at the bottom with the appropriate flame adjuster
PORTABLE SIZE & METAL MADE: This butane pipe lighter with a small size(size: 2.8” x 1.4” x 0.5” / weight: 0.11 lb) is made of high quality zinc alloy. So it is easy to carry and comfortable to hold
