Upgraded 100cc Bicycle Engine Kit 2 Stroke Motorized Bike Engine Kit Gas Motorized Bicycle Engine Kit Super Fuel-efficient Bicycle Motor Kit Fit for 26″-28″ Bikes, 44 Teeth Full Set
Price: $69.99
(as of Sep 29, 2024 17:30:14 UTC – Details)
Bicycle Engine KitBicycle Engine Kit
CUBELLIN Upgraded 100CC 2 Stroke Bicycle Engine Kit
Upgraded Gas Powered 100CC 2 Stroke Bicycle Engine Motor Kit Fit for 26″-28″ BikesThe 44 Teeth Bicycle Engine Kit can convert a regular bicycle into a motorcycle AND includes all the parts and accessories. Ideal for upgrading your regular bike to an electric bike.
Motorized Bike Engine Kit Motorized Bike Engine Kit
Specifications
Material: Aluminum, IronDisplacement: 100CCNumber of Teeth: 44Ignition Mode: CDIFuel Tank Capacity: 2L/0.53galFuel Consumption: 2.5L/0.66gal/100kmFuel Number: #92, #95Max. Load Capacity: 200kg/440lbs
High SpeedBicycle EngineHigh SpeedBicycle Engine
44 Teeth Bicycle Engine44 Teeth Bicycle Engine
Gas Motorized Bicycle Engine KitGas Motorized Bicycle Engine Kit
45KM/28MI/H HIGH SPEED
The 100cc gas motorized bicycle kit is powerful and durable, with a High speed of 48km/h. Low fuel consumption, 150 miles per gallon.
STRENGTH AND SAFETY
4 bolts attach the engine to your bike frame and this Bicycle Motor Kit comes are 8mm vs the standard 6mm. The aluminum engine body, iron fuel tank, and iron chain have better durability, and when combined with sandblasting, painting, and shot blasting treatment, they can provide stable operation for a long time.
HIGH PERFORMANCE CARBURETOR
50mm bore single piece cylinder/head (increased weight capacity, lower operating temps, easier starting, sustained power output across varied rpm range).
11
Package Included
1 x Bicycle Engine Kit1 x English ManualAll Accessories for Assembly Fuel Type: Mixed Fuel(16 Gasoline: 1 Two-stroke Engine Oil During Break-in Period, 20 Gasoline: 1 Two-stroke Engine Oil After)
3.5 out of 5 stars
15
3.5 out of 5 stars
15
2.0 out of 5 stars
6
2.0 out of 5 stars
6
$69.99$69.99 $69.99$69.99 $189.99$189.99 $189.99$189.99
Engine Displacement
100CC 100CC 100CC 100CC
Engine Type
2 Stroke 2 Stroke 4 Stroke 4 Stroke
44 Tooth Bicycle Engine Kit: Sproket :44 Teeth. The 44 Teeth Bicycle Engine Kit can convert a regular bicycle into a motorcycle AND includes all the parts and accessories. Ideal for upgrading your regular bike to an electric bike.
Super Fuel-Efficientt: The 100cc motorized bicycle kit is powerful and durable, with a top speed of 48km/h. Low fuel consumption, 150 miles per gallon. Max. Load capacity:200kg(440lb).
Double Strength and Safety: 4 bolts attach the engine to your bike frame and this Bicycle Motor Kit comes are 8mm vs the standard 6mm. That means the mounts are twice as strong and twice as secure. The aluminum engine body, iron fuel tank, and iron chain have better durability, and when combined with sandblasting, painting, and shot blasting treatment, they can provide stable operation for a long time.
Complete Bicycle Motor Kit: Our package includes all the parts to convert your bicycle into a motorcycle, meeting your needs with just one purchase! This bicycle engine kit is more suitable for people with lower budgets or only short-term needs for motorcycles.
Upgraded Tunable High Performance Carburetor: Choke lever on the handlebars, Main jet. (Can be re-jetted), Pilot jet, Copper oil needle , Idle RPM Screw, Idle Air Screw and has an Internal choke circuit that delivers more fuel with the choke on, instead of restricting air. 100CC Bicycle Engine Kit Great for cold weather starts!
Excellent Performance Bike Engine Kit: 50mm bore single piece cylinder/head (increased weight capacity, lower operating temps, easier starting, sustained power output across varied rpm range).
