Price: $14.98
(as of Aug 18, 2024 10:00:27 UTC – Details)
Prepare Accinouter Portable Weather Alert Radio Before Hurricane,Flood,Strong Storm Weather or Earthquake. As A Must Have Survival Tool, Every Family Need Our Emergency Radio !
It’s lithium battery may not have the umph to power your macbook through a conference, but it’ll certainly give your gadgets enough juice for that all important call to your family, the emergency services or for contacting roadside assistance and getting you back on your journey.
Other Specifications:
Maximum Power Consumption : 3W
AM : 520-1710KHz, FM: 87-108MHz, NOAA: 162.40 ~ 162.55MHz
Working Voltage : 2.7V to 4.2V
Battery: Polymer Li-ion
Dimensions :5 x 2.4 x 1.8 inch;
Weight : 0.66lb: Small enough to fit in your pocket.
Package:
1x Weather radio
1x Micro USB charging cable
1x User Manual
Before Hurricane,Flood,Strong Storm/Snow Weather or Earthquake. As A Must Have Survival Tool !
3 Charging Ways :
We understands that an emergency rarely respects your daily routine, plans, or the power provided by your gadgets’batteries. That’s why we came up with a device that is easily charged through 3 innovative features:
1. Micro and Standard USB ports for conventional charging.
2. Solar Panel for when you’re stuck in the sun with no outlets in sight.
3. Kinnetic hand crank for the battery boost when the odds are against you.
Once it’s powered, you’re looking at a battery that will go. With enough light to last you through the night or provide up to 7 hours of radio on a full charge. Remain in the loop even when you’re offline with AM / FM radio and the latest weather updates from NOAA.
Rechargeable By Multiple Ways: 3 charging ways, Hand crank, Solar charging, Micro USB cable. Can charge USB port devices such as smart phones.To keep you connected and powered. Hand Crank Self-charge for Outage, 2000mAh rechargeable battery provides up to 10 hours of light or 4-6 hours of radio broadcast.
Compact and Portable : As a durable small size tool, you can pack the radio in your emergency toolbox. Better yet, it also can work as a portable battery to charge your USB devices and a quick emergency call will help you get out. Keep it in your trunk, your suitcase, or carry it by hand with the attached lanyard.
Table Lamp & LED Flashlight : This Emergency radio designed with a led flashlight in front of the radio, useful for emergency and survival situations to light up dark areas or to keep your room bright after a storm cuts off your power.
Emergency Supply Bag : Perfect for after dark disasters. More than a radio, this weather radio is a hassle-free way to listen to important weather or news updates. 1000 mAh battery for charging your phone in case of the emergency, bright long lasting 1W powerful LED flashlight to keep you safe in case power outage. As a emergency preparedness kit with you in camping, backpacking, hiking or any other outdoor activities.
