Price: $542.95 - $76.99
(as of Aug 23, 2024 19:15:22 UTC – Details)
HAOKEO Backup Camera for Truck with 7 Inch Monitor
This is a wired backup camera that is very easy to install, you don’t have to worry about not being able to install it yourself!
Multi-function RV Backup Camera to Improve Your Driving Quality
This backup camera has a lot of functions, I believe it can meet your multi-functional needs, to ensure your driving safety!
1 Parking Grid Line 2 130° Viewing Angle 3 Touch Buttom 4 Super Night Vision
Rear View Camera Easy to Install How to install the monitor?
We provide a bracket for the 7-inch monitor. It is the suction cup mount. You can fix the monitor to the dashboard or windshield.
How to install the camera?
Simply connect the monitor to the cigarette lighter and wire the camera and monitor. The wiring can be done as shown in the diagram.
IP68 Waterproof Camera
No worry to use a lot of water flushing car, rain, or snow.
2 Channel Video Input
The backup camera with monitor with two video input V1 and V2.
18 IR LED and 6 Glass lens
Pretty Clear Video, 6 lens glass, and 18 IR LED lights.
Image Filp
With the image flip function, you can switch the screen to rear view/front view.
Backup Camera for Truck Trailer Camper RV VAN SUV
【Super Night Vision & IP68 Waterproof】The backup camera for truck 18 IR optical back up camera is IP68 rated waterproof. No need to worry about rinsing your vehicle with a lot of water, or rain or snow. The backup camera kit has 18 IR lights, super night vision function to ensure you can drive safely no matter day or night.
【Stable Signal Transmission】The wired backup camera adopts wired transmission, compared with wireless backup camera transmission, the signal is more stable and reliable. We equip you with a very strong cable, so you will not easily lose the signal.
【Dual-Channel Camera System】The backup camera has 2-channel video input, high image resolution, full-color display with low power consumption, adjustable brightness, contrast and color. And the installation of two channels back up camera is as easy and efficient as one.
【Parking Grid Line & Image Flip】The backup camera with monitor has a parking line, and the image can be flipped according to your needs, to ensure that you driving more easily and efficiently.
【720P HD and 130°wide viewing angle】The rv backup camera has a 7-inch 720P HD display that provides a clear and realistic image display, enabling drivers to see vehicles behind them as well as obstacles more clearly. The backup camera’s 130° field of view angle covers a wider range, reduces blind spots and improves safety.
★★★★★ 3 years of maintenance and 24 -hour customer service support to ensure your satisfaction. If you encounter a problem, contact us immediately. Our 24 -hour customer service can always be used for useful help, quickly replace damaged parts to ensure that your system work normally ★★★★★
