Price: $798.23
(as of Aug 09, 2024 00:30:19 UTC – Details)
TRUMA COOLER C69DZ DUAL ZONE
The Adventurer
The Truma Cooler C69DZ Dual Zone is our smaller dual zone model. The versatility of dual-zone temperature control allows you to maintain two temperatures in your cooler unit at once. Perfect for long weekend trips with the camper or your next barbecue.
Cools down to -8°F even at high temperatures in summer!
The cooler can cool or freeze down to -8ºF. You can adjust the exact temperature to the nearest degree.
Portable Fridge/Freezer
The perfect choice for your next barbecue, trip or long weekend with the camper. There is even enough space for upright standing bottles.
Powerful: cools reliably down to -8°F. Flexible: compatible with 12/24VDC or 110VAC power Robust: particularly reliable and durable thanks to its stable design Efficient: high-quality insulation reduces power consumption Space-saving: spacious interior and retractable handles
Specifications
Volume (Gal) 6 + 12 Gal (18 Gal) Volume (Quart) 24 + 48 Quart (72 Qt) Zones Dual DIM IN (WxHxD) 29x22x18 Temp Range -8°F to 50°F (-22°C to 10°C) DC Power Two 12/24V DC outlets AC Power One 110V AC outlet Average Hourly Amp Draw 0.8 Lid Split Lid Removable 2-way
Sophisticated Functions
Operation via Digital Control or App
You can adjust your settings on the digital display of the portable fridge/freezer or use the free Truma Cooler App.
DC Power Connections on Both Sides
12V connection is located on two sides of the box, giving you much more flexibility. Tablets and smartphones can be charged at the USB port.
Versatile Storage Solutions
Our Single Zone models are true space savers. Basket inserts can be removed as needed and flexibly divided. The lid of the Truma Cooler can also be removed.
Details Make the Difference
Retractable carrying handles (on both sides) which saves space when installed in a vehicle. In addition, two integrated bottle openers and LED interior lighting.
Operation and Power Supply
You can change the settings via the intuitive digital display on the cooler. Alternatively, the cooler can also be adjusted via Bluetooth using the Truma Cooler App. If there is an unexpected problem – for example, because of a loose cable or an interrupted power supply – it will be indicated by a flash code on the display. You will also receive a corresponding notification / recommended action directly on your app.
The Truma Cooler C69DZ can be powered by the car battery (permanently connected to the vehicle or via a 12 V socket), 110 V mains power or a portable battery. In addition, you also have the option to use your cooler self-sufficiently via solar panel.
The portable fridge/freezer also has a built-in battery monitor. This means that the Truma Cooler C69DZ automatically disconnects from the car battery if a critical value is reached.
5.0 out of 5 stars
1
4.2 out of 5 stars
4
5.0 out of 5 stars
1
3.3 out of 5 stars
4
5.0 out of 5 stars
1
$687.95$687.95 $733.62$733.62 $964.73$964.73 $1,054.31$1,054.31 $798.23$798.23 $1,054.12$1,054.12
Volume
8 Gal/32 Qt 11.5 Gal/46 Qt 19 Gal/76 Qt 28 Gal/112 Qt 24 + 48 Qt/72 Qt 44 + 54 Qt/98 Qt
Temp Range
-8°F to 50°F (-22°C to 10°C) -8°F to 50°F (-22°C to 10°C) -8°F to 50°F (-22°C to 10°C) -8°F to 50°F (-22°C to 10°C) -8°F to 50°F (-22°C to 10°C) -8°F to 50°F (-22°C to 10°C)
Weight (lbs)
41.1 50.5 64.4 75.9 67.4 77.5
Dimensions IN (WxHxD)
24x17x13 26x19x16 29x22x18 36x20x21 29x22x18 36x20x21
AC
One 110V AC outlet One 110V AC outlet One 110V AC outlet One 110V AC outlet One 110V AC outlet One 110V AC outlet
DC
Two 12/24V DC outlets Two 12/24V DC outlets Two 12/24V DC outlets Two 12/24V DC outlets Two 12/24V DC outlets Two 12/24V DC outlets
0.5 0.6 0.6 0.8 0.8 1.1
Zones
Single Single Single Single Dual Dual
Lid
Removable Removable Removable 2-way Removable 2-way Split Lid Removable 2-way Split Lid Removable 2-way
Product Dimensions : 29 x 18 x 22 inches; 69 Pounds
Item model number : 45105-01
Date First Available : March 13, 2020
Manufacturer : Truma
ASIN : B0862D9BNF
POWERFUL COOLING PERFORMANCE – Our long-lasting Truma compressor coolers reliably cool or freeze down to -8ºF(-22°C), even at high outside temperatures. Easy operation: accurate temperature control and adjustment on intuitive digital display or via app.
HIGH CAPACITY – 17 Gallons/72 Quarts of usable volume. The cooler has space for upright standing bottles and includes a versatile removable basket insert to adjust contents. Our compressor coolers are available in 8 different sizes (8-28 Gal/30-104 Ltr usable volume).
EFFICIENT & QUIET – From 50ºF to -8ºF degrees, any temperature is possible. Thanks to excellent insulation, the Truma cooler remains chilled for a long time, even when there is no power supply nearby. It runs with a low-noise operation over long time periods and can be powered via car battery, solar power, portable charger, mains power or a Truma Battery Pack.
SPECIAL FEATURES – Stylish, robust, stable, and durable design; LED interior light; space-saving flat carry and tie-down handles; integrated bottle openers on both sides; USB port for charging smartphones or tablets; easy cleaning thanks to built-in drain feature.
VERSATILE – Whether camping, heading on a trip, or barbecuing with friends: With a Truma compressor cooler, you can rely on your mobile refrigerator. Also available are Truma Cooler insulated cover (for better energy efficiency and reduced power consumption), and Truma Battery Pack for cooling without mains electricity.
