Travelers RV Backup Camera Wireless for Trailer: RV Enthusiast Back up Camera with 7 Inch DVR Recording Monitor – Install-Free Magnetic RV Camera for Furrion Voyager Series RVs A8
Price: $179.99 - $139.98
(as of Sep 13, 2024 05:15:13 UTC – Details)
rv backup camerarv backup camera
AMTIFO wireless backup camera system is a better choice for RV travel lover. It can be used for safe reverse or driving monitoring.
AMTIFO A8 Trailer Backup Camera Easy to Install 2-12-1 How to install the 7 Inch monitor ?
Come with U-shaped brackets for the 7 Inch monitor. You can fix the display on the dashboard. Also the monitor can be powered via car charger or USB power cable
magnetic backup cameramagnetic backup camera How to install the rv camera ?
Battery-operated magnetic camera is installation-free, can be mounted on any vehicle with ferrous metal and is compatible with both Furrion and Voyager systems.
rv backup camera wireless wireless backup camera for rv rv camera system 4-4 4-5
1 2 Channels
2 Recording Function
3 Strong Signal
4 No Delay
5 Touch Button
5-1 5-2 wireless rv backup camera back up camera for rv trailer rv rear view camera
1 Adjustable Gird Lines
2 Images can be flipped
3 Wide View Angle
4 Durable Metal Camera
5 HD 1080P Image
Perfect for wide variety of large vehicle 77
AMTIFO A8 wireless rear view camera is compatible with RV/Pickup/Truck/Bus/Van/Trailer/Camper/5th wheel/Motorhome/boat/rig etc large vehicle.
100% WIRELESS TRANSMISSION: wireless backup camera utilizes FM technology for a fast 2.4GHz WiFi connection that’s strong against interference. Enjoy a signal transmission range of up to 50 feet from vehicle. The magnetic dual rv camera system comes with a built-in 15,000mAh battery and a 3W solar panel, portable and truly achieving installation-free.
Ideal Companion for Safe: The rv backup camera is designed for RV and trailer enthusiasts of all kinds, this camera offers a safe, convenient experience. Suitable users for RV-Renter, RV Club Members,Camping-Fan,Retiree,Traveler,Large-Vehicle-Driver,Outdoor Adventurer, Nature Photographer, or a Long-Term Triper, The back up camera for truck rv is tailored to enhance driver enjoyment on the road.
APPLICABLE WIDELY: The rv backup camera wireless is best ideal for some of the larger vehicles, suitable for RV,trailer,camper,truck, motorhome,5th wheels, boat,tractor, rig,van,cargo etc. It is also compatible with Furrion and Voyager series RVs, helping you see areas that are out of sight, providing a wider field of view, and reducing the risk of collisions. If your vehicle is made of materials such as aluminum, plastic, or fiberglass, the system inlcude 1 metal bracket for use with it.
EQUIPPED WITH 6 POWERFUL NEODIUM IRON BORON MAGNETS: The magnets that hold the wireless backup camera for rv in place are extremely strong and are covered with a thin layer of protective rubber that prevents scratches to your car’s paint! The 6 powerful magnets increase the magnetic force by 6 times, with a maximum pulling force of 40kg, and can be firmly attached to any part of most metal products. It won’t come off even during emergency braking, over speed bumps, or on rough roads!
VIDEO RECORDING FUNCTION:The trailer camera has an video recording and loop recording option, which works just like a car recorder to record what happens around the RV. In case of an accident or collision, the trailer backup camera will save the video clips separately to keep the most valuable evidence. It supports up to 128G SD card, when the storage card is full, it will automatically overwrite the old video and keep the latest recorded video.
SAFETY AND SECURITY: You can use it as an rv camera system wireless to help you park your car easily at the campground and have a good view of what’s behind you while traveling on the road. It has completely changed someone who loves camping experience on the road. Also it can adjust the width of the parking line, move the parking line left/right/up/down to make it reflect the real situation, and even turn on/off the parking guide line according to your preference.
PICTURE QUALITY: The display is equipped with HD 1080P color sensor for more realistic image colors. Provides clear, real-time rear images, making reversing and driving easier and safer. The low light rv reverse camera uses an extremely smart and powerful chip with superb night vision that works reliably on cloudy days, at dusk, dawn or midnight. 170 Wide angle, perfect for seeing trailers and multi-lane traffic, yet balanced to avoid fisheye distortion as much as possible.
OTHER MORE FUNCTIONALITIES: Combines the solar backup camera with a large 7-inch monitor that allows you to see behind you while driving and assists in backing up, and the display incorporates a sunshade cover that effectively prevents glare from interfering. In the menu, you can switch between front and rear view, and turn on or off the guide line, which is very convenient. The picture is clear and adjustable brightness, contrast, color and so on.
