Price: $7.99
(as of Jul 22, 2024 11:00:19 UTC – Details)
Torch Lighter, Lighters for Candles, Windproof Butane Refillable Torch Flame Lighter, Multi Utility Lighter for Fireplaces Campfires BBQ Grill Pilot Lights, 4Pack(Shipped Unfilled)
How to Refill Your Lighter
1.Choose the Right Butane Can, Refillable with LONG UNIVERSAL REFILL TIP Butane Canister.
2.Bleed the Lighter, Push on the Lighter Refill Valve with a Screwdriver to Let Out the Air Inside until no Hissing Sound is Heard. Air inside the Fuel Tank Prevents bButane from Being Injected into the Tank and Cause the Lighter to Malfunctions.
3.Injecting the Butane, Hold the Lighter and the Butane Can in an Vertical upside-down Position, Press the Stem of the Butane Can into the Refill Valve in 3-second Bursts to Inject the Butane. It is Normal for a Small Amount to Spray around the Edges of the Valve.
4.Before Igniting the Lighter, Please wait 3-4 Minutes, this Allow the Excess Butane to Evaporate and Gas Inside Lighter to Reach Room Temperature.
Rotatable Head, Our Mini Torch Lighter Features 45 Degree Rotatable Head Provides You with Enhanced Flexibility and Precision.
Reliable&Safe, Safety Lock to Prevent Accidental Ignition, Child-Resistant Safety Mechanism Keeps Your Children Away from Using Them.
Butane Refillable, Unlike Disposable Lighters, Our Torch Lighters are Butane Refillable, Offering you a Co-Effective Solution.
Wind Resistant, This Mini Butane Torch Lighter Works Well Even in Wind Conditions with an Effective and Hot Flame.
Transparent Fuel Tank: Visible Butane Tank, Remind you When you Lighter Needs to Refill and the Check the Filling State. It Has 2.8g Capacity Butane Fuel to Ensure Long Last Using. (Butane Fuel is Not Included).
Multi-Purpose Lighter, Suitable for Indoor and Outdoor Activities, Such as Lighting Candles, Fireworks, Grills, Fireplaces. Also Useful for Lighting your Fireplace, Gas Stove, Oven, Hob, Tealight
Continuous Flame Mode: Press the Ignition Button to Light Fire, Turn the Safety Lock to “Lock” Position at the Same time, Then it will Keep Firing without Your Pressing.
