Price: $43.98 - $20.99
(as of Sep 14, 2024 01:30:14 UTC – Details)
Titanium Round Carabiner Clip, Spring Hook Key Chain Ring, Small keyring Carabiner
Titanium Alloy Material: Key carabiner clips super light, half lighter than stainless steel. Mini carabiner with high strength, high temperature resistance & corrosion resistance features, widely applied in aviation and medicine fields.
Dimensions: Titanium round carabiner: outer diameter about 36 mm/1.4 in, inside diameter 26 mm/1 in, thickness 0.19 in. Stainless steel d ring dimension: 0.73 in (L)x 0.67 in (H). Total weight: Ultralight only 0.44 oz (12.5 g), less burden in your daily and outdoor life.
Sandblasted Surface: Sandblasted surface treatment, colorfast, scratch-resistant and durable. Simple and Elegant.
Innovative Construction: Titanium key clip innovative spring structure created using titanium’s tensile strength. One-piece spring clip with circle springback control system, not easy to loose and deform.
What You Get: 1 x Titanium keychain carabiner+1 x 316 stainless steel D ring+1x screwdriver; white box.
