Price: $16.99
(as of Sep 14, 2024 18:45:24 UTC – Details)
TISUR Swivel Key Chain Rings Connector
Made of genuine 316 stainless steel
Anti-allergic / never fade / no rust, scratch resistant With high hardness & lightness. STURDY and DURABLE
360 Degree Swivel Integrated Design.
Swivel part is simple tough & reliable, always keeps smooth rotation.NO BULK TO KEYCHAIN.Small & Compact for your EDC Keys.
High Load Bearing
Though the swivel key ring connector has a small body, it holds a high load bearing beyond imagine.Picture showing is a load of water of 16 LITRE.No worries about the safety of holding small accessories like home keys, keys for work, or any pendants.
Key Rings for Key Chians
TISUR keychains keyrings accessories, free combined as your needs and preference.
Solved issue with your keys and keychains
–car keys, truck keys, home keys, and keys for work…
and really helps the fob and keys move more freely.
Small Hole
Inner Diameter: 0.23 inch/6mm, can be paired with normal size key rings.
Large Hole
Inner Diameter: 0.29 inch/7.5mm, can be attached with several small key rings.
Connect with D-Ring, brings more flexible for big key fobs.
Special DIY Connectors
360° Rotatable Rings, can be your great project accessories for DIY Crafts, Connectors for Necklace/Tassels/Jewelry Making.
1,560
4.6 out of 5 stars
277
320
4.6 out of 5 stars
247
4.5 out of 5 stars
77
4.7 out of 5 stars
214
$19.99$19.99 $19.99$19.99 $19.99$19.99 $13.90$13.90 $13.90$13.90
Material
Titanium Titanium Stainless Steel Titanium Stainless Steel Stainless Steel
360° Swivel
Surface/Color
Polished/Bright Silver Sandblasted/Grey Sandblasted/Silver Sandblasted/Grey Sandblasted/Silver Sandblasted/Silver
Premium Materials: Swivel key ring is made of 316 stainless steel material, anti-allergic / never fade / no rust, scratch resistant. Durable and Heavy Duty for longtime using.
360 ° Swivel Key Ring : Keychain connectors can be rotated 360 degrees, the swivel keychain can help you quickly find the keys you need, avoid your keys tangled together, more convenient to use.
Lightweight And Stylish: The small key ring is small in size and light in weight, only 0.87 inches (22 mm) x 0.42 inches (11 mm) and weighs only 0.15 oz. It doesn’t add weight to the keychain. Fashion unique shape design, let you stand out in the crowd.
Wide Application: Key rings are used in a wide range, besides being used as Keychain Accessories, they can also be used to connect small parts such as hooks, necklaces, jewelry, labels, DIY crafts, etc. Swivel key rings are also ideal gifts for dads, friends, etc.
What You Get: 2pcs stainless steel swivel connector+white box; If you can’t open the white box, please put it in a warm place for a while before trying again.
