TISUR Swivel Key Rings for Keychains, 360°Rotatable Key Chain Rings for Keys, DIY Crafts Jewelry Making Connector Project Accessories (Polished-2 Pack)
Price: $36.89 - $17.99
(as of Aug 08, 2024 19:15:21 UTC – Details)
quick release keychainquick release keychain
TISUR Swivel Key Rings for Keychains, 360°Rotatable Key Chain Rings for KeysTISUR Swivel Key Rings for Keychains, 360°Rotatable Key Chain Rings for Keys
TISUR Swivel Key Rings for Keychains, 360°Rotatable Key Chain Rings for Keys,TISUR Swivel Key Rings for Keychains, 360°Rotatable Key Chain Rings for Keys,
Made of genuine 316 stainless steel
Anti-corrosion, anti-rust, long lifetime.With high hardness & lightness. STURDY and DURABLE.
TISUR Swivel Key Rings for KeychainsTISUR Swivel Key Rings for Keychains
Free Rotation Swivel Key Chain Rings Connector
360 Degree Swivel Integrated Design.
Swivel part is simple tough & reliable, always keeps smooth rotation.NO BULK TO KEYCHAIN.Small & Compact for your EDC Keys.
Compact / Lightweigt / Cool Shining Looks / This is Exactly what you were looking for !!
TISUR Key Chains Rings Connector with Detachable KeyringTISUR Key Chains Rings Connector with Detachable Keyring
Swivel keyring for keychain,Titanium carabiner Car key chain for Men and WomenSwivel keyring for keychain,Titanium carabiner Car key chain for Men and Women
Fine Finished Surface
Polished
Bright silver color, with a beautiful luster
Sandblasted
Matte silver color, with elegance and stylish
Inside Diameter
Small Home
Inner Diameter: 0.23 inch/6mm
Large Home
Inner Diameter: 0.29 inch/7.5mm
High Load Bearing
Though the swivel key ring connector has a small body, it holds a high load bearing beyond imagine.Picture showing is a load of water of 16 LITRE.No worries about the safety of holding small accessories like home keys, keys for work, or any pendants.
Customize Keys Key Rings and Keychains as you prefer
Cool Necklace Connector
Bright Silver Finish makes it has a shinning surface.
Looks cool used as a necklace connector.
Car Keys Connector
Connect with D-Ring, brings more flexible for big key fobs.
Key Rings Organizer
Small home is paired with normal size key rings.Large home can be attached with several small key rings.
This small key ring connector makes it possible to bring the keys, tools, accessories you need by your side.
Perfect Connector
Solved issue with your keys and keychains
–car keys, truck keys, home keys, and keys for work…
and really helps the fob and keys move more freely.
1,458
317
317
4.5 out of 5 stars
2,098
4.5 out of 5 stars
2,098
1,192
$16.99$16.99 $19.99$19.99 $19.99$19.99 $17.90$17.90 $17.90$17.90 $22.90$22.90
D-Ring Size/Material
W*H: 1.18 “x0.74” (Stainless Steel) W*H: 1.18 “x0.74” (Stainless Steel) W*H: 0.95 “x0.93″ (Stainless Steel)
O Ring Size/Material
Outer Diameter: K22-0.9”/ K27-1”(All Titanium) Outer Diameter 1.26”(Titanium) Outer Diameter 1.26”(Titanium) Outer Diameter 1.26”(Titanium)
Capacity/Surface
Medium/Matte Small/Polished Small/Matte Large/Matte Large/Matte Large/Matte
Suitable for-
Crafts/Accessory/Keys for home/ work Car Keys/Crafts/Accessory Car Keys/Crafts/Accessory Belts/Crafts/Accessory/Keys for home/ work Belts/Crafts/Accessory/Keys for home/ work Belts/Crafts/Accessory/Keys for home/ work
Premium Materials: Swivel key ring is made of 316 stainless steel material, the swivel keychain has been polished finish, allergy/colorproof/rust resistant, scratch resistant.Durable and Heavy Duty for longtime using.
360 Degree Swivel Key Ring : Keychain connectors can be rotated 360 degrees, the swivel keychain can help you quickly find the keys you need, avoid your keys tangled together, more convenient to use.
Lightweight And Stylish: The small key ring is small in size and light in weight, only 0.87 inches (22 mm) x 0.42 inches (11 mm) and weighs only 0.15 oz. It doesn’t add weight to the keychain. Fashion unique shape design, let you stand out in the crowd.
Wide Application: Key rings are used in a wide range, besides being used as Keychain Accessories, they can also be used to connect small parts such as hooks, necklaces, jewelry, labels, DIY crafts, etc. Swivel key rings are also ideal gifts for dads, friends, etc.
What You Get: 2pcs stainless steel swivel connector+white box; If you can’t open the white box, please put it in a warm place for a while before trying again.
