Thermos Reusable Ice Mat Food Saver, 36-Cube
Price: $5.74
(as of Aug 01, 2024 19:30:21 UTC – Details)
The 36 cube ice mat is perfect for use with Thermos coolers to help keep contents cold. Multiple layers of polyethylene are heat-sealed together to create a strong bond and each cube contains water-based solution (not for human consumption). You can store the mat in your freezer until you are ready to use, it will remain flexible when frozen. The cube mat is food-contact safe, reusable and durable.
Cube mat is food-contact safe, reusable and durable
Each cube contains water-based solution (not for human consumption)
Store in your freezer until ready to use: mat remains flexible when frozen
Each cube contains clear, non-staining purified water
