Price:
(as of Aug 19, 2024 20:30:15 UTC – Details)
1 Weather, AM, FM Radio 2 2,000mAh Power Bank 3 2 LED lights
1 Recharge with USB-C Port 2 Hand Crank for power 3 Includes AAA Batteries 4 Power with the sun
What radio frequency can this radio pick up?
This radio can pick up AM (522-1710 KHz), FM (87 – 108 MHz), and Weather Bands (162.400 – 162.550 MHZ)
How long does its battery last?
The built-in battery (when full) will play the radio for roughly 14 hours.
Can this radio be used to charge other devices?
Yes, you can use the built-in 2,000mAh lithium-ion battery to recharge devices through the Output USB port.
Is this radio waterproof?
No this radio is not waterproof, please keep it in the carrying case to help protect it while not in usage.
Radio: AM: 522-1710 KHz, FM: 87 – 108 MHz, Weather Bands (162.400 – 162.550 MHZ) LED flashlight: 120LM LED reading light: 100LM SOS light: Yes SOS siren: 85DB Built-in Battery Runtime: Radio: 14 hours LED light: 7-10 hours Built-in Battery: 3.7V 2000mAh li-ion rechargeable battery Backup battery: AAA batteries (included) USB output: 5V 1A USB input: 5V 1.2A Hand crank: Yes Solar Panel: Yes Size: 155*94*49mm Weight: 275g Operation temp range: -10°C to 50°C or 14°F to 122°F
Contents Included:
1x Emergency radio1x USB charging cable3x Backup alkaline AAA batteries1x Lanyard1x Protective hard case1x User manual
Plan for unforeseen emergencies – Tenergy’s multifunctional NOAA weather radio is a must-have tool during disasters such as power outages, hurricanes, or earthquakes; built-in tools such as led flashlight, SOS siren, USB power bank, and radio frequencies like AM, FM, and WM are critical in a crisis.
Multiple ways to power – recharge the built-in 2000mAh battery by generating energy with the hand crank or solar panel, or through other power sources such as the included AAA batteries or USB power source.
Emergency flash lights and siren – illuminate the dark with the two LED flash lights that can shine up to 120 lumens, or use the SOS light and siren which flashes SOS in Morse code to alert others to accidents or urgent situations.
Backup battery bank – the built-in li-ion battery in this weather alert radio can double as a renewable power source for cell phones and electronics when fully charged.
Tested and certified by CE, PSE, Rohs, and includes Tenergy’s lifetime support with our team based in California.
