SYLVOX 24” TV 12/24 Volt TV 1080P FHD RV TV, with Digital Video Disc Player FM Radio Base and Digital Noise Reduction, Suitable for RV Camper Kitchen Bedroom Boat, RT24R2GNDA 2023
Price: $269.00 - $220.09
(as of Aug 09, 2024 06:00:37 UTC – Details)
1.SYLVOX 24-inch DC flat-screen TV, built-in Digital Video Disc player, with a base, and high-resolution digital noise, suitable for RVs travel and home use.
2. 12Volt TV: 10.5V~28V full range wide voltage protection, which can effectively deal with the influence of unstable power supply voltage in the car on the RV TV when the RV starts and stops. Support DC voltage 12v/24v power supply, or use the attached adapter to connect to a home AC voltage 110v power supply.
With anti-reverse connection technology, when the positive and negative poles of the DC power supply are reversed, the TV will not be short-circuited, which effectively protects the TV.
3.Built-in dual 5W speaker cabinet , to provide high-quality sound. The square base bracket is earthquake-resistant . Designed for light motorhomes, caravans, motorhomes, boats, bedrooms, kitchens and home use
4 . ARC and USB port for connection to USB or hard drive for recording and playback program file, or through the ARC connection VAST box or media player. With a built-in Digital Video Disc player, you can watch your favorite movies.
5. One-key scanning: Sylvox RV TV can be easily used in mobile environments such as boats and RVs . A simple function- SCAN is added to the remote control . When moving to a new location, just press the “Scan” button, and the 12V TV will pass and retune to the new location and get all the channels in the new area.
We include a 100-240V adapter and a 12V cigarette lighter, so you can power it directly from a 12V socket, or you can power it throgh the adapter in the bedroom, kitchen.
The square base bracket has good shock resistance and can withstand bumps, potholes, and uneven roads.
Specification:
Resolution: 1920 x 1080 HD
Tuner: ATSC
Connection method: USB ARC VGA
Voltage range: 10.5-28V DC
Aspect ratio: 16:9
Brightness: 220 cd/m2
Wall mount VESA : 100 x 100mm
Product size: 548.78*48.60*366.26mm
Standard: ATSC
Refresh rate: 60Hz
Power: 34w
Viewing angle: 178°H/178°V
Weight: 3.2Kg
Ports: EARPHONE, DC, ARC, VGA, PC AUDIO, AV, TV, COAX, USB
Accessories: remote control (including battery), power cable, adapter, square base, screws, manual, cigarette lighter.
SYLVOX TV suitable for DVD/VCD/CD discs, does not support playing Blu-ray discs.
Small Portable TV: Built-in dual speakers and FM radio function, allows you to listen to a variety of audio programs outdoors.
Multiple Protection Design : 12 Volt TV support DC 12v/24v (DC wide voltage 10.5V-28V ) power supply, recoil protection (when the voltage changes sharply, it can become flat and will not damage the circuit), reverse connection protection (No short circuit even if the positive and negative terminals are reversed)
Excellent experience: 24 Inch TV Built-in Digital Video Disc, integrated ASTC tuner, with USB, ARC, VGA port, cabinet speaker, reduced distortion, excellent broadband sound effect. 178°H/178°V ultra-wide viewing angle experience. With square bracket base, cigarette lighter, adapter and other accessories.
Use place: Travel and home Both, Full HD TV suitable for traveling campers with, trailers, RVs and home bedrooms, kitchens, lounges and other places of the perfect TV, through the included adapter to convert the home AC power to DC power to power the TV, thereby achieve home use effect.
Anti-seismic design, passed the 4G vibration test.6 pin DC port Anti-drop design, the plug is not easy to fall in the process of vibration.
