Price: $499.99 - $421.99
(as of Sep 07, 2024 22:45:24 UTC – Details)
Stay connected in your home or office with SureCall’s Fusion4Home, the most powerful cell phone signal booster that provides strong, reliable connections for talk, text, and fast 4G LTE data throughout homes or small buildings in the most remote and challenging areas. The Fusion4Home features 2XP technology, which doubles the uplink transmission power (up to 26 dBm) to maintain your connection throughout the weakest cell signal environments. Assembled and tested in the USA with outstanding build quality, award-winning technologies, all-carrier compatibility, and world-class support, the Fusion4Home is the premier cell phone signal booster for the home or small building.
POWERHOUSE BOOSTER— Fusion4Home is the most powerful cell phone signal booster in its category and is designed to improve cell service in the weakest signal areas. The innovative and easy-to-install DIY booster system improves 5G & 4G LTE cellular signals for multiple users in a home or cabin, up to 5000 sq ft. It instantly boosts voice, text and data signals on all 5G and 4G LTE phones for enhanced connectivity on all North American cell carriers, including Verizon’s 5G Nationwide network, AT&T, T-Mobile, Straight Talk, US cellular and many more.
HIGH-PERFORMANCE KIT— Maintain a strong phone-to-tower connection even in the weakest signal areas with SureCall’s patented 2XP technology that DOUBLES uplink power back to the cell tower. 2XP extends your cellular range to help you stay connected, make calls, and use apps where you couldn’t before. Fusion4Home features the highest uplink power and a high-gain Yagi antenna for accessing faraway cell towers, which results in fewer dropped calls, improved battery life, higher audio quality, faster data speeds, and better streaming quality.
EASY DIY INSTALL— Fusion4Home comes kitted with SureCall’s most powerful outdoor Yagi antenna that is directional and designed to be aimed towards the closest cell tower to capture and provide the best indoor performance and coverage. Simply set up the Yagi antenna, run the included RG-6 cable (50 ft) into your home, and mount the base unit in a central location. Then, attach the interior cable (20 ft) to the panel antenna and mount the antenna on a wall so it is facing the area where you would like improved signal. The base unit will automatically boost your signal once it is plugged in.
FOR BEST PERFORMANCE— Finding a location with consistent signal that the Yagi antenna can capture is important and will improve performance. Indoor coverage area is directly related to the existing signal strength available at the exterior antenna location: 1-2 bars outside ~ 2000 sq ft inside, 3-4 bars ~ 3000 sq ft, 5 bars ~ 5000 sq ft. If there is weak signal where the exterior antenna is installed, we recommend a booster kit that includes components to capture and broadcast a stronger signal, like the Fusion4Home Max. If there is no available signal to boost at the exterior antenna location, a signal booster will not work.
BUILT TO LAST— Designed, assembled, and tested in the USA and built with the highest-quality components and made to last with outstanding build quality in durable housing with multiple patents and award-winning technologies. SureCall boosters are FCC-approved and include industry best 3-year warranty with lifetime 100% US-based tech support. SureCall is proudly American-owned and operated since 2001, based in Silicon Valley California. SureCall is an Authorized Verizon 5G Signal Booster Vendor.
