Price: $12.99
(as of Aug 03, 2024 16:30:13 UTC – Details)
EASIER,FASTER & CLEANER
NO FUEL.NO GAS.NO FLAME.NO HARM. You don’t need to buy lighter butane refill again and again. Electric lighter use more cleaner power than old fashion fuel-based lighter. Just plug into powered usb port and take it everywhere.
PORTABLE DEVICE
Pocket size makes it easy to carry and use anytime anywhere. Let you get away from fire burn and spark.
RECHARGEABLE BATTERY
This Electric-Arc Lighter use Li-ion battery, it can be used 40-60 times per charge. Battery can be charged more than 500 times.
HIGH SECURITY
For the safety of consumer, it will auto stop beyond 10 seconds per igniting.
WINDPROOF DESIGN
This design makes it work even in heavy winds. Keep a distance of the fire without the fear of burning without spark and no smell, it is comfortable for daily use.
Flexible Neck
The front section can be rotated 360 degrees. This design make it much easier to use in any direction. The arc lighter is not only windproof, but also let you get away from fire burn.
Upgrade Electric Lighter
This arc lighter has 360° retractable and flexible neck and is waterproof, windproof and fall-proof.
Waterproof, Dustproof & Wind Resistant
Good waterproof effect. Rubber Buckle, Inner Rubber Seal, dual protect design make it perform well. High quality shell gives you a good handle feeling.
Multipurpose Use
Includes wrist lanyard and survival emergency whistle for easy carry. You can hang it around your neck, clip it to your belt, or remove the clip to put in your pocket, handbag, drawer, or car compartment.
Flexible Neck
Multipurpose Use
If you want to store your device long term, two key factors will affect the overall health of your battery: the environmental temperature and the percentage of charge on the battery when it’s powered down for storage.Conversely, if you store it fully charged for an extended period of time, the battery may lose some capacity, leading to shorter battery life.Depending on how long you store your device, it may be in a low-battery state when you remove it from long-term storage. After it’s removed from storage, it may require 20 minutes of charging before you can use it.Disabled After Using a Few Times If you can not charge it after using a few times, please check whether the lighter has been dropped from a high place or its USB interface is toughed with water or other liquids.
Safe Flameless Arc Lighter
Camping Fire Starter Tool
Good outdoor waterproof effect
4.3 out of 5 stars
8,190
4.3 out of 5 stars
45,129
8,680
4.6 out of 5 stars
1,648
4.5 out of 5 stars
1,246
$7.99$7.99 $6.99$6.99 $6.99$6.99 $9.99$9.99 $9.99$9.99
Item Dimensions
7.48 x 0.59 x 0.35 in 6.89 x 0.59 x 0.59 in 10.27 x 0.59 x 0.59 in 7.28 x 0.59 x 0.43 in 10.62 x 0.78 x 0.47 in
Item Weight
1.23oz 1.64oz 2.4oz 1.72oz 2.32oz
Battery Capacity
220mAh 220mAh 220mAh 170mAh 360mAh
Let SUPRUS bright your journey!
【CONVENIENT&DURABLE】- Stainless steel wire closure for secure storage and a water-resistant O-ring seal to keep rain, snow and moisture out when the cap is closed. Includes a wrist lanyard for easy carry. Note: DO NOT touch the arc with hands.
【MULTIPURPOSE USE】-Windproof and flameless,usb rechargeable arc lighter. It is a perfect outdoor lighter,camping fire starter tool,an emergency fire starter tool,edc camping survival tactical gear and more.
【BUTANE FREE】- No more harmful butane. SUPRUS uses plasma tech to eliminate the need for this harmful chemical. Simply plug in to any USB port(like computer or car or mobile phone portable charger)with the included USB cable. It can be quickly fully charged in 1.5 hours. During the ignition, there will be noise of “ zee,zee”, which is high-voltage power generation, please use with relax.
