SUPRUS Candle Lighter Arc USB Lighter Electric Lighter with Upgraded LED Battery Display Safety Switch Rechargeable Flameless Plasma Windproof Portable for Birthday (Birthday Blue)
Price: $6.21
(as of Aug 20, 2024 08:15:22 UTC – Details)
candle lightercandle lighter
lighterlighter
lighterlighter
SUITABLE FOR DIFFERENT OCCASIONS
Arc lighter also can be used as Flameless Candle Lighter, Plasma Bean Lighter, Camping Lighter, BBQ Lighter, Kitchen Lighter, Torch Lighter, Fire Starter, Fireplace Pilot Lighter. Outdoor Utility Lighter Suit for birthday candle, BBQ grills, camping, and many other uses.
Package Include:
1 * USB Rechargeable Windproof Arc Lighter
1 * Type C cable
1 * Gift Box
lighterlighter
Retractable Head Protect Cover
This design is the additional cover to protect retractable head from damage, and make it hard to put hand into the arc operating region.The tips are made of heat resistance ceramics (the ceramics do not burn). You can clean the tip parts of lighter with soft cloth.
lighterlighter
Battery Notification
This is the upgraded SUPRUS arc lighter which can display real time battery volume. When 4 LED lights on the barrel turn on, it is full charged.
lighterlighter
Children Safety Button
Need to slide out the tip and press the activation button. Slide-Out Tip is design for preventing mistakenly touching.
lighterlighter
USB Charging System
Simply connect to any powered USB port, just take 40-60 minutes full charge, lighter can be used more than 500 times(fire cubes).
lighterlighter
lighterlighter
lighterlighter
lighterlighter
USB Charging System
Let SUPRUS bright your life!
Frequently question respond
Is this easy to light? My mom doesn’t have the strength to use a traditional candle lighter.
Yes, it is easy to light. All you have to do is press the little power button that is on it and then hold it to the wick. The candle will be light in seconds.
Is the rechargeable lighter safe to use to light gas stove?
Yes, it can be used for light gas stove. And for the safety of consumer, the igniting spark will auto stop beyond 10 seconds per igniting.
Does this electric arc lighter come with USB charging cable and what type of charging cable?
Yes, it comes with a charging cable. You can use the USB port to charge it through computer. If it is missing, you can use a mobile phone charging cable. They are the same kind of charging cable.
How to clean the tip parts of the lighter?
The tips are made of heat resistance ceramics ( the ceramics do not burn). But carbon from candle soot and charring wax produced by candle burn when lighter literally jamming it into the wick . You can clean the tip parts of lighter with soft cloth .
【TREBLE SAFETY DESIGN】 – Our lighter had passed CE, RoHS, UL test. Adopt the updated version of bonnet, which gives you treble protection, you have to push the safety lock switch first, then press the ignition switch to work. For the safety of consumer, the igniting spark will auto stop beyond 7 seconds per igniting. Restart the switch, the igniting spark will be re-ignited.
【PORTABLE & CONVENIENT 】Wind & Splash Proof Design prevents the electric pulse produced from being blown out by strong wind, The lightweight design makes the lighter easy to carry and ideal for camping, BBQ ,hiking ,indoor and outdoor activitiess.
【BATTERY NOTIFICATION】This is the upgraded SUPRUS arc lighter which can display real time battery volume. When 4 LED lights on the barrel turn on, it is full charged.
【BUTANE FREE】No more harmful butane. SUPRUS uses plasma tech to eliminate the need for this harmful chemical.During the ignition, there will be noise of “ zee,zee”, which is high-voltage power generation, please use with relax.
【WHAT YOU GET】SUPRUS rechargeable lighter, USB type C charging cable, a gift box, a user manual and 24h friendly services.
