Price: $7.99
(as of Jul 29, 2024 05:45:22 UTC – Details)
Wisdompro 12 Pack Small Split Rings – 10mm (Single Size Only)
Excellent combination of strength, corrosion resistance
What is Titanium Alloy?
Titanium is known for its two most useful properties: corrosion resistance and strength-to-density ratio. Titanium alloys are metals that contain a mixture of titanium and some other chemical elements.
Why Titanium Alloy?
1. Lightweight and strong – Its high strength-to-density ratio means it can be strong and lightweight at the same time.
2. Corrosion resistant – It is highly resistant to corrosion even in sea water.
3. Biocompatible – It is non-toxic and non-allergenic, and can even be used in biomedical implants.
4. Durable – Wisdompro Split Ring is made of Grade 5 Ti, which is significantly stronger than commercially pure titanium while having the same stiffness and thermal properties.
Note: These split rings are Small!
Endless Application: Great for Keys, Curtain, Jewelry Making and DIY Craft, etc.
4.5 out of 5 stars
1,775
4.5 out of 5 stars
1,719
4.6 out of 5 stars
1,004
280
4.3 out of 5 stars
37
4.5 out of 5 stars
233
$9.99$9.99 $8.99$8.99 $9.99$9.99 $9.99$9.99 $8.99$8.99 $8.99$8.99
Color Options
black, pink, red, purple, yellow, mint black, pink, red, purple, blue-gray black, red, purple black, brown, blue black (round/flat connector) black+black, black+silver
464
4.5 out of 5 stars
2,036
4.5 out of 5 stars
7,830
4.5 out of 5 stars
445
4.5 out of 5 stars
171
4.6 out of 5 stars
260
$6.99$6.99 $7.69$7.69 $6.39$6.39 $8.99$8.99 $7.99$7.99 $8.99$8.99
Material
Stainelss Steel Nickel-plated Stainless Steel Stainelss Steel Nylon Polyester
Outside Diameter: 10mm; Thickness: 1mm; Height: 2mm (NOTE: These split rings are SMALL!).)
Made of Titanium Alloy Material – Corrosion resistant, Hypoallergenic, and Non-magnetic
High tensile strength, anti-deformation
Great for connecting clasps, charms, links and other jewelry
Wisdompro Retail Package includes: 12 x Titanium Alloy Split Ring (10mm) and 1 x Wisdompro 4×4″ Microfiber cleaning cloth
