Price: $199.98
(as of Aug 09, 2024 03:45:37 UTC – Details)
Driving Safety, Enjoy Life!
DoHonest, a reliable leader and innovator of consumer electronics smart devices integrating R&D, production and sales.
We have been focusing on reversing safety, continue to develop different styles of backup cameras after listening to customers’ preferences. You can enter our DoHonest store to choose a wireless or wired system. Choose a 4.3″/5″/7″ monitor screen. If you are a car and travel lover, don’t miss us.
Wireless for easy installation
A must-have for driving safety
Plug and Play: This RV backup camera wireless requires no wiring, no drilling, and no need to connect car lights. The 6 super strong neodymium magnets on the bottom of the RV camera can be effectively attached to the iron surface of the vehicle, so you don’t have to worry about it falling off even when driving on the highway. The large 7-inch monitor can be easily powered by the included cigarette lighter or USB power cord. The whole installation process only takes 1 minute even for a novice.
Strong and Stable Signal: With more advanced 2.4G wireless digital frequency hopping technology, the wireless backup camera for trailer is able to restore true and clear images on the display and effectively avoid signal interference. Also, the magnetic backup camera adopts 2024 unique dual-antenna design and CIS chip, which offer a more stable signal and a 60% higher refresh rate. The signal can reach up to 328ft in open areas, with a working range of up to 180ft on vehicles.
Rechargeable Portable Camera: Built in 10500mAh large capacity rechargeable battery, a single full charge (8 hours full) can be used for up to 18 hours, making it especially suitable for long-distance traveling. The solar backup camera also comes with a 5W solar panel and a 5V-2A TYPE-C charger, both of which provide the trailer camera system wireless with longer battery life when the battery is low or the sun is low.
Durable and Energy-Saving: Simply turn off the power to display when system is not in use. The camper backup camera will quickly enter energy-saving sleep mode in about 60s. You no longer need to manually power off RV camera, which will reduce the frequency of charging. Its case is made of aluminum alloy material,which has better heat dissipation. Built-in 3 lithium batteries have over-charging, over-discharging and short-circuit protection functions,which greatly improves its service life.
2 Video Channels and Loop Recording: Built-in recording system automatically overwrites old footage to keep recordings refreshed. In the event of an accident or impact,the system automatically protects that video segment for your use later. RV back up camera for travel trailers supports up to 2 cameras and easily switching between them, set full screen or split screen. With it, you can record your travel as you go and share beautiful scenery for your family or friends.
HD 1080P Quality: The wireless backup camera for rv has been upgraded to the latest AHD camera system, with a built-in CCD sensor that converts analog light into digital pixels, providing better resolution (1920*1080). It is more sensitive to light, so it produces fewer particles and better image quality. You can clearly see everything behind you on the monitor. It is a friendly camera for novice, female, and elderly drivers.
Excellent Night Vision: The 9 infrared lights on trailer backup camera will automatically come on at night or in low light conditions, illuminating the back of the vehicle and capturing a clearer image. With this rv rear view camera, even nighttime driving is safe, perfect for frequent nighttime driving, monitoring livestock in horse trailers, and backing up in tight areas.The 940nm infrared light is milder and not as harsh as LED white lights, providing better concealment when monitoring.
Multi-functional Camera: RV reverse camera is fully sealed with waterproof rating up to IP69K, which makes it more durable under physical impacts like bumps, knocks and humidity. The rubber material on bottom of camera prevents scratches on the paint surface and protects your car. 150 degree distortion-free view angle,8 all glass lens,and f/3.5 aperture make pictures clear and undistorted.USB waterproof charging port and 4 battery level indicators let you know the remaining battery level easily.
7-inch LCD Monitor: 7’’ monitor can be mounted on the dashboard or windshield using the included suction cup or U-shaped bracket. LCD screen maintains image consistency from multiple angles, and the included sunshade effectively avoids glare from direct sunlight, improving your eye comfort. And you can adjust brightness, contrast, saturation, flip image, adjust the parking lines and more on the display. With this wireless trailer camera system, your journey will be safer and more enjoyable!
