Solar Magnetic Wireless Backup Camera with Battery + 5 Inch Monitor System, LASTBUS 2 Split HD Display + Rechargeable IP69 Waterproof Night Vision Rear View Camera for RV Car Trailer Truck Camper
Price: $119.99 - $129.99
(as of Sep 06, 2024 12:00:29 UTC – Details)
Magnetic Wireless Rechargeable Backup Camera + 5 Inch Split Screen Monitor System
5in-magnetic202211145in-magnetic20221114
Rechargeable Wireless Backup Camera Powered by Built-in 9600mAh Large-capacity Battery
wireless magnetic backup camerawireless magnetic backup camera
5 Inch 2 Split Screen Monitor System for RV Truck Trailer Camper Car
magnetic backup cameramagnetic backup camera
Magnetic Wireless Backup Camera System with Adjustable Parking Assisting Grid Line
5-inch-prrking202211115-inch-prrking20221111
IP69 Waterproof Magnetic Wireless Backup Camera System
waerproof-night20221111waerproof-night20221111
Infrared LED Night Vision Backup Camera System
night vision240703night vision240703
LASTBUS Magnetic Wireless Backup Camera + 5 inch Split Screen Monitor System
TESTTEST
Tips:
1. Make sure that the antenna is firmly mounted on the rear view camera and monitor. The antenna will ensure a strong wireless digital signal.
2. If you want the photos to be displayed all the time, please connect the backup camera with constant power supply.
Battery Capacity: 9600mAhWaterproof Rate: IP69Lens Angle: 170°Infrared Distance: 32 feet 5 Inch Split Screen Monitor (Supports 2 Channels)
Screen Size: 5 InchPower Supply: DC 12V-36VReversing Line Adjustment: Up/ Down/ Left/ RightImage: Mirror/ Flip/ Mirror + Flip. Brightness, contrast, hue are adjustable.
【Built-in Powerful Magnetic Base, Easy to Install】 With a strong magnetic base, LASTBUS solar wireless backup camera can be instantly attached to any position of the car. It can be moved at any time according to your preference, and you can take it down when not needed, convenient and fast.
【Built-in 9600mAh Rechargeable Battery】With the 9600mAh battery, LASTBUS wireless solar backup camera can work continuously for a long time. It can recharge by usb port and solar power. Compared with other products, this camera do not require additional power cables, so the installation is safer and easier, saving you a lot of time.
【Strong and Stable Wireless Digital Signal】LASTBUS wireless backup camera adopts digital wireless signal chip, which has stronger and more stable signal. Achieve stable connection up to 330ft, transmit HD and stable video even on the highway, no delay and anti-interference. Perfect for Car, RV, Trucks, Trailer, Camper, Pickup, van, etc.
【DIY Parking Assisting Line】 You can adjust the width/height, left/right position of the parking assisting line according to your actual needs. You can also turn it off if you don’t need it. So this camera is suitable for all kinds of parking needs and different heights of cars.
【5 Inch 2 Split Screen Monitor】This wireless backup camera systemr can add an additional camera to reduce the blind spot in driving and make the journey safer. (This item contains only one camera. If you want to add a second camera, please contact us.)
【Professional Waterproof & Super Night Vision】With fully sealed technology, this rear view camera has IP69 waterproof feature. You don’t need to worry about the camera being eroded by rain. Infrared LED light automatically turns on night vision mode when it detects insufficient light, providing you with a clear long-distance night view. Whether it is rainy or other bad weather, day or night, LASTBUS backup camera has excellent performance.
