Price: $30.98 - $14.99
(as of Aug 11, 2024 17:00:30 UTC – Details)
1. Does iRonsnow IS-088 support AAA battery?
A: It doesn’t support. iRonsnow IS-090 supports.
2. Can iRonsnow IS-088 charge iPhone/iPad/Kindle/Gopro/Blackberry?
A: It can charge iPhone 5/6/7 Plus and iPad Air. Can charge Kindle/Gopro/Blackberry/Android phone which support USB charge.
3:Does iRonsnow IS-088 support headphone jack?
A: It doesn’t support. iRonsnow IS-092 supports.
4.How does the weather radio work?
A: Only when you turn on the NOAA channel, it will issue the alert.
5.How bright is the light on a scale of 1-10? 1 a dim candle and 10 a superbright LED.
A: It’s about a 9. (answered by customer Tigdi). Seller answer: 5000lux @120mm, 0.25W/7 Lumen.
6. How is the range on the am/fm?
A: Generally, 60KM (38 Miles) for FM, 100KM (62 Miles) for AM. Depend the area, some customer answer: I live in the very rural central Arizona outback, and I pick up my favourite Phoenix AM station, some 120 miles away, better than my regular radio
7. what’s the effect of the solar panel?
A: It depend the weather. Actually it is a SURVIVAL EMERGENCY radio, can not work as a professional solar power bank.
iRonsnow IS-088 Dynamo Emergency Solar Hand Crank Self Powered AM/FM NOAA Weather Radio, LED Flashlight, Smart Phone Charger Power Bank with Cables
iRonsnow is a registered brand on USPTO. Only iRonsnow Official is authorized Seller.
Packages:
-iRonsnow IS-088 Radio
-USB Charging Cable
-Wrist lanyard
-USB Converter
-DC Cable
-User Manual
Warranty:
-30-Day Money Back Guarantee
-12 Month Replacement Warranty
-Lifetime Support Guarantee
【Newer Upgraded】 iRonsnow created this classic emergency radio and upgraded to 2000mAh power bank, For charging iPhone / smartphone via Type C USB cable directly when you need.
【Charging Indicator】Add Charging indicator to know charging level anytime, 4 lights mean 25% 50% 75% 100% of power. A must for emergency, Take this AM/FM/NOAAportable emergency weather radio with you anytime. A particular device designed to receive emergency warnings for various weather events as thunderstorm, flood, snowstorm, hurricanes, tsunamis.
【SOS & Two Led Mode】1W Super-Bright flashlight is made by LED & Long Press SOS Alarm Flashing Mode. After upgraded, effectively extends the use time.
【3 Rechargeable Ways】USB fast charging is the main power way in daily use, hand crank and solar power these two power sources are capable of regenerating power to keep the radio when you need in emergency. Power up anytime and anywhere. Keep your phone&devices online all the time.
【You get Compact Survival Radio】Size: 5 x 1.8 x 2.4 inches, iRonsnow emergency radio, Type C USB cable, User manual, and TWO years exchange warranty.
