Price: $129.99
(as of Sep 09, 2024 03:15:13 UTC – Details)
Solar & Rechargeable Camera
Camera Installation Diagram
IP67 Waterproof Camera
Monitor Installation
Package Contents
5 Inch 1080p Wireless Backup Camera Monitor
【Digital Wireless, Stable Signal】Digital wireless reversing screen and 1/4″ CMOS Sonix can transmit up to 600 feet in open areas, and the signal is very stable for common pickups, trailers, RVs, etc. The camera is powered by solar energy and rechargeable batteries, and the monitor is powered by a cigarette lighter power supply, no wiring is required between them, eliminating the most troublesome part of installing a reversing camera system.
【Solar Powered Portable Rechargeable Camera】Backup camera wireless with powered solar panel, rechargeable during sunny days when driving. The camera can be removed from the bracket at any time easily,you can power the camera through the USB port in winter or in times of lack of sunlight. The camera uses waterproof material IP69 waterproof.
【2 Camera Channels Support】5″ display supports 2 wireless rear camera inputs, you can add a second camera as a front or side view camera. Freely switch images between CAM1 and CAM2 to avoid blind spots. Note: The second camera should be purchased separately.
【DIY Parking Grid lines】 Reverse camera can adjust the parking line’s width, moving them Left/Right/Up/Down or mirror flip to make them portray real conditions, or you can also turn the parking guide lines off you prefer.
【Gesture Control and One-touch Wake-up/shutdown】 The display has an infrared sensor, which means that gestures can be used to control menu switching modes and switching CAM1 CAM2 channels. Equipped with a wake-up function button to start and shut down the back up camera systems wireless.In order to save energy and power, The monitor can be set to display for 45s/60s/90s once for reverse use.
