Price: $29.99
(as of Aug 14, 2024 02:30:17 UTC – Details)
Stay Ready for Any Situation
Our SUNGLIFE emergency radio will help you stay connected to the latest news and updates even when the Internet is down or the power is out.
FM/AM/NOAA Coverage
All the standard radio channel options are available, including AM/FM and NOAA weather bands for staying informed. Picks up signal from the NOAA weather band radio with great reception once you turn it on and tune it in.
Multi-funtional Charging Mode
The SUNGLIFE Emergency Radio can be charged via hand crank, micro USB cable, three AAA batteries or solar power. Additionally, the 2000mAh rechargeable battery can provide up to 30 hours of Flashlight or 8 hours of Radio time (it can also charge up; portable devices such as smartphones and tablets).
Red LED SOS Beacon Light
The emergency radio also includes a bright Cree LED Flashlight, just in case the situation gets dark and dangerous. The included flashlight has also SOS beacon capabilities and produces Morse code flashes.
Products Specification:
AM / FM / NOAA
AM: 520 KHz to 1700 KHz
FM: 87 MHz to 108 MHz
Battery Power: 3x AAA / 2000 mAh 3.7V LI-ION Rechargeable Battery
Weather Band: 162.40 to 162.55 MHz
Flashlight: LED Flashlight / Reading Lamp
1 minute hand-cranking supports over 5-7 minutes of continuous lighting or 3-5 minutes of continuous radio usage
Dimensions(LWH): 6.57 x 2.22 x 3.2 inches
Package Contents:
1 x Weather Radio
1 x User Manual
1 x USB Charging Cable
AM/FM/Weatherband radio: keeps you informed of the latest weather alerts from seven NOAA weather stations and local AM and FM programs
Multi-powered: power with manual charge, solar, USB, or batteries. It is the perfect radio to take with you to keep in touch with the outside world whilst camping or bushing walking. It includes a inbuilt Solar Panel and Dynamo hand crank charger that allow you to recharge the internal battery or charge any device by USB or mini USB including your mobile phone. Besides, the radio has a battery compartment which operates separately to the internal battery. It supports with 3x AAA batteries
Built-in bright LED flashlight/personal SOS Alarm: the radio includes a powerful torch and locator siren with visible beacon for emergency situations, when you need to gain to attention of emergency services, family, or rescuers
Compact design: 6.57″(L) x 2.22″(W) x 3.2″(H), you can throw it in a backpack, glovebox, or your emergency kit and have the confidence of being able to listen in to the radio, use the torch, or work as a portable battery to charge your USB devices with out fresh batteries
Everyday portable radio: Great for everyday use, too, this mini emergency radio gives you 5-7 minutes of continuous lighting or 3-5 minutes of continuous radio usage with each minute of handcranking
