Semi-Truck Sun Shade for Windshield and Side Window | Sunshade Maximum Coverage Windshields for Truck – Block UV Sun Heat Rays – Best for Semi, Commercial & Big Rig Truck, RV(Side Windows Suction Cup)
Price: $25.99
(as of Sep 03, 2024 03:00:18 UTC – Details)
meakeize – idea for your life
sunshade1sunshade1
Why choose meakeize sunshade?
Comprehensive sun protection, effectively resisting 98% of UV damageFull coverage, effectively reducing the temperature in the carProtecting dashboard to prevent sun damage, agingProtect personal privacyUnique suction cup design, without any additional equipment in the car, sucker stable and efficientAdapt to the wide and narrow windshield, easy to overlap and can be adjusted
0101
0202
0303
Protect The Car Interior
With our semi-truck sunshade, you can prevent the car interior from being damaged by high temperature.
Full Coverage
Sunshade maximum coverage windshields for truck – block UV sun heat rays.
Sleep Well
The sunshade for car windshield can block the sunlight, you can take a good break when you’re tired , and the temperature inside is also cooler than without sunshade.
xipanxipan
Suction cup fixed
Side Windows adopts Suction Cup, which is easily attached to the glass, firmly, and can be pulled out anytime, anywhere. No need to add any accessories in the car
0202
Width Adjustable
Semi Truck Sunshade features can overlap the circles to adjust the width.
xipanxipan
0202
anzhuanganzhuang
How To Use
1.Slide shade against the windshield.
2.Adjust sunshade to find the best coverage.
3.Suction cups hold the side windows and fix the sunshade.
How To Fold
F01F01
F02F02
F03F03
F04F04
1. Fold it in half
2. Twist it in opposite direction
3. Be a circle
4. Store in pouch
rightright
How to remove the sunshade correctly?
You need to pull the tail of the suction cup to disassemble it. Notice: Don’t pull the sunshade when disassembling, which will damage it.
MULTIPLE ADAPTABILITY
MULTIPLE ADAPTABILITYMULTIPLE ADAPTABILITY
Complete sun proteciton: Windshield and Side Window for sun protection while ensuring driver privacy. Size: 163.5″ Length, 36″ Height, and the Ring Diameter 32″, fit with the wide as well as narrow windshields with easy overlapping
Quality materials: Truck Sun Shade is made of durable 240T Nylon Polyester covers; Quality Silver Reflective material to reflect 98% of the harmful UV sun rays and blocks sunlight, effectively lowers the temperature in the car (up to 40° F)
Unique design: Side Windows adopts Suction Cup, which is easily attached to the glass, firmly, and can be pulled out anytime, anywhere. No need to add any accessories in the car
Easy to Use & Store: Foldable Windshield Sunshade has quick spring action which helps to open and folds easily and can be carried easily with the sunshade storage pouch
Compatibility: Compatible with most Semi, Commercial, and Big Rig Trucks,RV and so on. Make sure to measure your windshield dimensions before ordering
