Price: $15.99 - $9.90
(as of Aug 22, 2024 04:15:21 UTC – Details)
CKEDES SELF STIRRING COFFEE MUG
New upgraded Automatic Mixing Cup is definitely a savior for lazy people, no need for a spoon, just add your favorite powder (coffee, butter, coconut oil, heavy cream, etc.) Press the touch switch and the drink is ready. Whether it is at home, office, gym, school, etc., no additional mixing tools are required, which is very convenient.
RAPID COOLING
The method of physical increase and decrease of temperature difference is adopted. Under the condition of high temperature, 85 ℃ hot water can be continuously stirred for 3 minutes to cool down to about 55 ℃, and the most appropriate temperature can be drunk in the shortest time.
SUITABLE FOR DIFFERENT PLACES
Ideal for coffee, tea, hot chocolate, milk, protein shakes, lemonade, bouillon and many other light mix drinks that you can stir.Take your drink from your kitchen to the living room, bedroom, car, office, gym, school, etc.
FULL AUTOMATIC MIXING CUP
High temperature,difference resistance304 stainless steel linerEasy to cleanCompact and portable
PROCEDURE
Heat the water first,then add the coffeeDouble clicks to opensAutomatic quick stirringStraws can be inserted
Product Information
Name Ckedes Self Stirring Mug Main Body Material ABS Shell + Stainless Steel Capacity About 400ml/13.5oz Size 14*7.5*5.5cm/5.5*2.95*2.16in Box size 9 * 9 * 15cm Usb charging And this self stirring cup comes with a 400 mAh battery which can be used many times on one charge. Packing List 1 * Self Stirring Mug ;1 * Type-C USB Data Cable Warm Note Please add an appropriate amount of water before turning on the stirring function.
Self Mixer Mug Coffee Cups,Internal material:Stainless Steel, External material:Plastic.Insulated and Thermos Mug.WASH THE MUG before using it for the first time.Notice:Double click to start,Click once to close.
APPROXIMATE LIQUID VOLUME 0.4L.Height:14cm; Cup diameter: 7.5cm; bottom diameter of the cup: 5.5cm; box size: 9 * 9 * 15cm.
CONVENIENCE AND TIME SAVING:Use magnetic technology to stir anything you add! It makes getting ready in the morning so much easier. It can help you save time. If you like to keep stirring your drinks or can’t find a spoon when you need one, this self-stirring cup is for you!
USB CHARGING: The auto mixing cup is charged with a USB and does not need to buy an extra battery. You can charge for half an hour with your adapter before use. And this self stirring cup comes with a 400 mAh battery which can be used many times on one charge.
Product quality, trustworthy:If you have any problem with our product, please contact us at first, we will reply you within 24 hours.
