Price: $75.99
(as of Aug 04, 2024 03:30:12 UTC – Details)
Receive reports on severe weather and evacuation details.
View larger Public Alert certified radio receives all NOAA reports.
View larger Large LCD that can scroll through S.A.M.E. information
View larger
Sangean CL-100 Table-Top Weather Hazard Alert with AM/FM-RBDS Alarm Clock Radio
All Hazards NOAA Weather Radio Public Alert Sangean’s new compact Table-Top S. A.M. E. Weather Alert Radio is loaded with all the key features. The CL-100 is a Public Alert Certified weather radio and receives all NOAA reports informing people about severe weather advisories, monitors and warning conditions, civil emergencies, hazards, and evacuation details, so you can have more time to react before dangerous storms hit your area. When you’re in a tornado path, seconds can mean the difference between life and death and that’s when the Sangean CL-100 comes into play. A 3.5mm stereo Auxiliary Input socket is provided on the rear of the CL-100 to allow connection of an external audio device such as an MP3 or CD player. The CL-100 also has a built-in external alert output jack for other accessories (e. g. hearing/visually impaired, flashing light, in/outdoor siren/alarm).
NOAA and Public Alert Certified Weather Radio
The Sangean CL-100 radio has been tested and certified by National Oceanic and Atmospheric Administration (NOAA), meets CEA-2009-B (ANSI) for all Hazards Weather Radio. The radio is also listed as a Public Alert Radio. The CL-100 can function with either fixed/embedded antennas for great reception of AM/FM/Weather from all directions, or you may purchase the optional ANT-100 magnetic spiral antenna (sold separately) to zero in on distant or weak stations in remote areas. Finding the S. A.M. E. county codes on NOAA’s web-site is easy and you can simply program them into the CL-100 and store up to 25 county codes to sound alerts for surrounding counties as well your area’s weather forecast. You can also retain the latest 20 event message memories. Feeling safe is nothing like owning a Sangean CL-100, knowing that you can wake up when danger is approaching.
Digital Signal Processing with LCD Scrolling Display
It adopts a digital signal processing (DSP) chip and features up to 5 station presets for each AM/FM band. Using the preset buttons saves you time when searching for your favorites. The CL-100 has an auto-station-search function to scan all available radio frequencies and find the strongest AM/FM signal. It’s equipped with RBDS capabilities, which means the signal is decoded by an RBDS receiver and can provide a range of informational features including Program Service (PS) name, Radio Text (RT) message, Clock Time (CT) and Date. The CL-100 has a graphic LCM (128 x 64 pixels) LCD module with excellent display quality and a wide viewing angle. It can scroll S. A.M. E. event information across the LCD display. In addition, the CL-100 has dimmer and contrast control adjustment for viewing the display in the dark.
Dual Alarm and Auto Shutoff Features
The CL-100 is a perfect bedside alarm clock. You can set dual alarm times and choose waking to AM/FM radio or HWS (Human Wake-up System) buzzer alarms. There’s also a snooze button. In addition, the sleep timer can be set from 15, 30, 45, 60, 90, to 120 minutes. The radio can be turned off automatically, so you can fall asleep to the music and then later gently awaken you with the news, music or alarm. The bass and treble can be adjusted as well to get the crisp crystal clear audio sound.
Key Features:
- Deluxe table top clock radio
- All-Hazards S.A.M.E. weather radio
- Receive all NOAA weather channels and reports
- Certified Public Alert Radio
- LCD dimmer and contrast control
- Scrolling event information
- 5 presets each for AM/FM bands
- RBDS compatible
- Sleep timer settings from 15 to 120 minutes
- Store up to 25 S.A.M.E. county codes
- 3.5mm Aux-in jack to connect other audio sources
NOAA and Public Alert Certified Weather Radio Receives all 7 NOAA Weather Channels and Reports, S.A.M.E. Broadcasts up to 25 Programmable FIPS Location Codes with 3 Messages: Warning / Watch / Advisory Lights
Stores up to 20 Alert Messages and 10 Memory Station Presets 5 AM / 5 FM with EEPROM Back Up for Preset Stations
Dual Daily Alarms with Waking to AM / FM Radio or Buzzer Alarm, Sleep and Snooze Timers, LCD Dimmer and Contrast Control Adjustments and Bass & Treble Controls
DC Power Input, Stereo Headphone Output, AM, FM and Weather External Antenna Connections, Aux-in, External Horn or Light Alert Connection and Ground Terminal
Operates with Included AC Adapter or 4AA Batteries (not included)
DeLuxe Table Top, AM/M Clock Radio
All Hazards SAME Weather Radio
Receives all NOAA Weather Channels & Reports
LCD Dimmer & Contrast Control
